Radiator Repair
Old 01-29-2012, 08:45 PM
Arbiter343GS's Avatar
Radiator Repair
I have a 1966 Plymouth Fury III and the radiator has a leak in it(it seems like a fairly small hole). How much would a repair shop charge to fix it(estimate)?
Old 01-29-2012, 08:51 PM
Mine charges 60 bucks for a rod out.
Old 01-30-2012, 05:05 AM
62Furious's Avatar
JB weld is less than $10
Old 01-30-2012, 11:16 AM
I just dropped it off at a radiator shop, they quoted me at $60.
Old 01-31-2012, 02:03 PM
And I just went to go pick it up today, because it needs to be recored and i dont have the $300 they want for it.
Old 02-01-2012, 05:24 PM
scotts74birds's Avatar
I had a leak in one of the cooling tubes. I just pinched the hole shut with needle-nose. You might get a small jewelers torch kit from Harbor Freight and try your hand at brazing it!
Old 02-01-2012, 10:29 PM
bboogieart's Avatar
Couldn't hurt at this point, right? Always a good idea to try to learn a new skill.
Old 02-02-2012, 03:31 AM
BuckNeccid's Avatar
Solder it. Really easy to do with a propane torch, some flux and some way to get the old brass really REALLY clean.
And I grabbed one of the $180, 4 core aluminum , proper mounts already there for a b-body, off e-bay. It works great, fits well, and seldom gets to more than 10 degrees above thermostat rating, even on the hottest days.
Old 02-16-2012, 10:43 PM
Well, I finally tried my hand at soldering it and they werent just kidding that my core was total crap. The rows crumbled as I tried to solder the holes in them.
Old 02-19-2012, 08:06 AM
bboogieart's Avatar
Well the $180 for a new aluninum sounds better than $300 for a recore. Unless you want originality. I think your 66 is a c-body and I have read there is a ford explorer radiator that fits. Might find a good one in the junk yards for cheap. Here's the info I copied from a c-body site. Hope it helps.
"a plastic aluminum radiator for '97 through '01 ford explorer with v8. is quite small, core size is about 21 x 23, 2.25 inches thick (two row), It has mounting ears that sit perfectly on the frame rails, and the top mounts bolt to the core support."
dnlwstwd
10-12-2011 08:08 AM
gotdust
07-09-2010 03:23 PM
64fury
02-02-2010 05:42 PM
johnberetta
03-12-2009 04:18 PM
sundelin
01-25-2008 01:25 PM
Quick Reply: Radiator Repair
