latest brick wall
Old 03-28-2010, 05:01 PM
deadkelly's Avatar
latest brick wall
my build has stopped yet again . this time it's my oil rings .
you may already know i re-sleeved my block ( all 8 cyl ) back to std bore ( 4.250 ) i have new but old aria's forged dome top pistons ( 1972 manufacture ) these pistons have the .006" piston to bore clearance in the piston . so back in the day you could fit the pistons to your new 383 without machining .
i bought 4.250 std bore hasting molly rings ( 383 mopar / 427-454 chev )
the ring gap turned out perfect @ .018" but the oil rings wouldn't go in . we wreaked the first set of rings . so i got std bore speed pro rings same thing .018" compression ring gap . but the oil rings wouldn't go .
so my mate got on to the net & found out std rings have .005"+ oil rings & thats to big for our virgin bore .
so we think we've found the problem ??? not sure .
apparently i can get cast rings with .000 ( std ) oil rings so i might have to use the oil rings from a cast set with the molly compression rings i already have . fingers crossed but now my mate building the engine doesn't want to buy anything till the bores are measured by a third party now . now its getting the block to & from thats a mission . it's raining the crank is in , cam is in , timing all set . aaarrrrrrgh what a faaaaarrrrk around . I'm still off work & broke .
btw i put some old video footage of my ute in the members rides section . it's at the track .
Old 03-28-2010, 05:09 PM
Polaradude's Avatar
Shitty deal Ollie, hopefully the new rings will solve the problem M8.
Old 03-28-2010, 09:40 PM
67gtxclone's Avatar
That sucks dude. I hope you get it worked out. I hate it when something so seemingly simple turns in to a never ending nightmare.
Old 03-29-2010, 06:10 AM
deadkelly's Avatar
tell me about it . it was meant to be a re ring & bearings , cam change with new timing chain , cheap build i was planning . then found out needed re sleeving , lost job , injured hand . finger is hooked looks like i won't get clearance for work & maybe another operation off work for longer . but i'm still alive so live is good .
Old 03-29-2010, 07:25 AM
Polaradude's Avatar
Jesus Ollie, whatcha been doing M8 ? Stuck your finger in the wrong hole buddy ?
Old 03-29-2010, 07:47 AM
deadkelly's Avatar
thats not what caused it lol i stuck more than my finger in there hahaha .
Old 03-29-2010, 08:29 AM
67gtxclone's Avatar
Hey man, where there is life, there is hope. So since you are still alive, I am sure you will get back to work soon and get the engine together even sooner. Never give up! Give these troubles the finger and keep moving forward!
Old 03-29-2010, 08:33 AM
Polaradude's Avatar
Bahaaahahaha.
Old 03-30-2010, 10:24 AM
deadkelly's Avatar
for sure mate no probs . a mates coming around tomorrow to measure the bores . so will take it from there .
Old 03-30-2010, 10:45 AM
Little Demon
Red Devil's Avatar
good luck man, I hope you get it figured out soon
Old 03-31-2010, 09:05 AM
deadkelly's Avatar
f@cking get f#cked ya f#$king c#nt f@rrrrrrrrrrrrrk . i just spent ages typing all the latest , the paint scheme & all i hit back space & it all got f#cking wiped FAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARK C#NT
Old 03-31-2010, 09:10 AM
deadkelly's Avatar
well all is good
bores are fine & got pistons in . I'm going to bed f#cking peace of sh$t .
Old 03-31-2010, 01:08 PM
Polaradude's Avatar
well all is good
Bahahahahaha, nighty night Muffin
Old 03-31-2010, 06:19 PM
67gtxclone's Avatar
Damn! I wish I had been there to hear the full rant! Sounds like it was a good one!!!!
Old 03-31-2010, 06:25 PM
deadkelly's Avatar
hahaha it sure was good morning all
Old 03-31-2010, 08:13 PM
YellowThumper's Avatar
Saw a group of guys in a dougnut shop early the other saturday.
I guessing all in their 80s.
6 or 7 AM waiting for my order. Another one comes in, they all ask him how he is doing.
Simple answer: i woke up this morning, I am good.
That says it all.
Sometimes cars DO talk back...
Old 04-01-2010, 01:16 AM
deadkelly's Avatar
Talking what i was trying to say last night
all is good . the bores are spot on & the rings should be fine . it's just a wee bit more fiddly because of the valve reliefs i ground into the tops of the bores . my mate who's building my engine wasted a bit of time today checking part numbers on rings , but it seems the ones i have are the ones we need . so we only got 4 pistons in today but they all seem fine so tomorrows another day . grant can you get some paint codes for those sublime / limelight green colors . I'm not sure what is what , I'm thinking the brighter ones though to stand out in my black engine bay . i like the color of rocknrollfenders chally . it's gonna be a black whatever bright green & cleared alloy color scheme with a dash of msd red . sump black just so not to draw to much visual attention from the v8 hating cops & transport ******* . although i think it will be the sound thats more of a concern to them though .
Old 04-01-2010, 02:38 AM
Polaradude's Avatar
Do you want DuPont #'s or does it matter ?
Old 04-01-2010, 02:56 AM
deadkelly's Avatar
DuPont is quite common but what ever mate , is there a web site that has a color graph or color card ??? so i can get a idea . thanks grantios
Old 04-01-2010, 05:32 PM
Crazy4Carz.Com's Avatar
This is all you need! either click print and take this tp your paint supplier or just give them this number. It is that easy.
Old 04-02-2010, 02:56 AM
Polaradude's Avatar
That's pretty much the chart you were gonna get from me, atta boy Steve.
If you need the Dupont's let us know Ollie
Old 04-02-2010, 04:37 AM
deadkelly's Avatar
thanks Steve & grant
all pistons are in , crank & rods are all torqued up & rear seal in . cam is degreed in . cleaned sump today it was caked in silly-cone what a mission it is getting that off . whats a good method for removing silicon residue ? I'm going shooting for next 2 days , so back into it Monday .
Old 04-02-2010, 05:22 AM
Polaradude's Avatar
i hate to say it but razor blades work good, time consuming but they work.
Old 04-02-2010, 05:39 AM
  #24
deadkelly's Avatar
thats what i used razor blades , wire brush & finger nails . but it's still got that slimy feel . i was gonna try petrol then prep wash / wax & grease remover .
Old 04-02-2010, 05:51 AM
  #25
Polaradude's Avatar
Ya you can try that, it's gets really sticky then. Do you have a product called brakeclean ? Nasty stuff but works on a lot of that crap.
Old 04-02-2010, 06:30 AM
  #26
deadkelly's Avatar
what like brake cleaner in a spray can ? maybe not that brand but yeah .
now I'll be using a windage tray with 2 paper gaskets , any tricks of the trade to make these things seal up ? . the gear box shop dude " fixed " the leaky sump last time with like a tube or 2 of silicon on every face of gasket , sump , windage tray , gasket , block . & it still leaked ? . should i rough up the sump & windage tray with sand paper ?
Old 04-02-2010, 06:46 AM
  #27
Polaradude's Avatar
Ya the stuff in the spray can.
Did you check the bottom of your block for flatness around the mounting flange. There might be a wobble there bubby.
Old 04-02-2010, 07:09 AM
  #28
deadkelly's Avatar
Talking
the wobbles in your **** flow , great whoppers of things .
there is a bit of a wobble is the pan front & rear , i showed my mate today he thinks we'll far kit more trying to straighten it out . + he thinks it will pull sorta straight when we do it up . he's the man or best i got on hand anyway .
Old 04-02-2010, 07:15 AM
  #29
Polaradude's Avatar
Awesome.. Let us know Ollie. Hey, don't forget the wall of death pic on the weekend..hee hee
Be still cat.
Old 04-02-2010, 07:20 AM
  #30
deadkelly's Avatar
how could i forget it'll only be a hare or 20 with maybe a fox thrown in for good measure .
Quick Reply: latest brick wall
