which is more desirable for a 70 cuda?
Old 02-17-2012, 02:21 PM
barry's Avatar
I would love opinions on the desirability of an original 70 cuda V code convertible with a date coded 440 engine versus a 70 cuda convertible with a matching numbers 383 engine. assume the condition of both cars is the same. Also, which one do people consider a better long term investment.
thanks
Old 02-17-2012, 03:26 PM
mikerp76's Avatar
i would say the numbers matching car would be worth alot more.
Old 02-17-2012, 04:28 PM
You're kiddin me, here, right? A V code, even if it's not a matching block, if done otherwise correctly, should be worth WAY more money
The cat's meow with a car like that would be if you could find a "warranty" block to put in it.
Old 02-18-2012, 03:56 PM
barry's Avatar
the car already has a date coded 440 six pack. what is a warranty block?
Old 02-18-2012, 05:04 PM
A date coded block would probably be just as well. A warranty block is exactly what the name implies -- "back when" the car was under warranty the owner ruined the block, and the factory replaced the block/ short block/ long block on warranty. So the numbers no longer match.
Back before the "big financial crash" I've seen Cuda sixpack and hemi BODIES WITHOUT an engine go for nearly as much as a running 383 car.
Did you say this is a ragtop? I'll bet there weren't all that many made. Make sure they are "legit" and not a "rebody."
Old 02-19-2012, 03:54 AM
barry's Avatar
it is a real convertible. according to production stats only 29 v code convertibles were produced of which 12 were auto. it is legit and documented
Old 02-19-2012, 08:16 AM
In that case I don't see any possible way that a 383 car would ever be worth more money.
Old 02-19-2012, 01:20 PM
barry's Avatar
thanks
Old 02-20-2012, 07:23 PM
moparted's Avatar
the v code is worth 1/2 what it would be if the numbers matched
josehf34
33
01-31-2014 10:12 AM
robertherr
03-04-2012 05:49 AM
robertherr
02-18-2012 03:17 AM
Valcam
06-04-2009 11:47 PM
Doc
07-06-2008 11:10 PM
Quick Reply: which is more desirable for a 70 cuda?
