Sponsored by:
Sponsored by:
Oil filter wars.
Old 03-28-2009, 05:37 PM
theomahamoparguy's Avatar
Question Oil filter wars.
Thought I might start a discussion {argument}.
What is the best brand of oil filter?
I was about to replace my oil filter and bought a FRAM.
My bud just about told me I should considered mentally challenged.
I told him he was mentally challenged for owning a chevy and put on
the FRAM filter anyway.
I thought FRAM filters were considered to be of a decent quality.
All opinions welcome.
Old 03-29-2009, 02:38 AM
Polaradude's Avatar
They're all basically the same until you get into the aftermarket or industrial filters. I do like the ones with the nut on the **** of them though and that traction goo that fram puts on theirs. There's nothing worse when working on a friends car than having to pound a lrg screwdriver through a filter to get it off.
Old 03-29-2009, 04:52 AM
I've always used fram and never had a problem. I also use Wix on my j10 and those are good as well.
I've heard stories about people having issues with a certain brand of filters and they boycot them after that.
Old 03-29-2009, 05:56 AM
Commando's Avatar
There is a good website out there that has this exact topic, forget what it was, but anyways I use Wix. Fram is decent, but from the people who come into the shop they have a lot of ones that blow apart, the filter material, I assume that they are overused or something. There are a few brands out there that over filter and cause the flow of oil to go down, these are prone to coming apart.
Old 03-29-2009, 06:06 AM
Junior Member
TCPMeta's Avatar
I like K&N filters. has a 1inch nut welded on for easy install and removal. Also I found out I can use a oversized filter from a Ford 302 5.0L on my 3.5L high output.
Old 03-29-2009, 08:24 AM
i have used fram, and never had a problem, even witha high pressure oil pump, with the filter bolted directly on it
Old 03-29-2009, 11:10 AM
mitchs66's Avatar
I've been selling parts for almost 9 years out of 2 different stores selling many different brands of filters, my dad ran a garage most of my childhood and I've only seen a problem with an oil filter twice...first was a '85 dodge truck with a fresh overhauld 360 and fram filter, the filter came apart pluged the oil ways and spun a rod bearing. The customer had a good machine shop rebuild the engine and had all the tickets, and fram reembursed them the money (good on there part in my book). Second was a wix filter on a race car, the oil was 50w and the filter twisted the inside apart and the filter was like my daughter's ratle when it was removed. The engine had a high volume oil pump and thick oil running lots of high rpms, the wix reps said this is what the wix racing filters are to used with, not a standard wix filter. I'd say run what you like, i like Napa golds (wix), and a friend of mine with a '79 mustang and crate 514 always runs fram. I think the key thing is to stay up on oil changes...just my 2 cents.
Old 03-29-2009, 01:16 PM
Little Demon
Red Devil's Avatar
y'all know I don't have any mopars, only chevys so I use AC Delco
Old 03-29-2009, 04:10 PM
Polaradude's Avatar
I have heard good things about the new Royal Purple oil filters, they have that new glass medium filter material in them, don't know a whole lot about them technically but I heard they were good.
Old 03-29-2009, 07:14 PM
Hey thanks guys, Think I might try a Wix next time.
Old 03-29-2009, 08:10 PM
Senior Member
craveman's Avatar
you would be suprised how many different brands of oil filters are made in the same factory. a lot of brands use the same filter and put their name on it.
Old 03-30-2009, 03:50 AM
rr69half6bbl's Avatar
cravemans right. alot of products are done in the same place w/ diff. manuf. putting their own labels on them.When I was a teeneager, i worked in a grocery store. 1 day stocking shelves we got a load of green giant veggies in, 1 of the wrappers was messed up. so i pulled it off, here it had like 3 other brand labels wrapped up under the green giant label. all of them new. same w/ antifreeze, only 2 glycol plants I know of. they put the blend in diff. containers for the various com. like prestone, napa, etc. On oil filters, I use the napa gold have for yrs. never had a prob. you have good luck w/ something you stay w/ it.
Old 03-30-2009, 05:31 AM
Commando's Avatar
I believe there are only 2 or 3 filter plants out there that are the big names.
Hick727
01-10-2011 06:13 PM
Demonized
06-23-2010 10:39 AM
BuckNeccid
05-05-2010 02:53 PM
Commando
12-24-2008 12:44 PM
dzltd02
10-28-2008 08:25 AM
Quick Reply: Oil filter wars.
