Go Back   Mopar Forums > GENERAL > General Discussion
Thread Tools Display Modes
Old 08-12-2008, 08:33 PM   #1 (permalink)
67 GTX
Oil Problem with all Cars!!!!
The Zinc has been removed from the oil, and because of this, it is causing cam failure in most OHV engines. To fix this, you need to buy a zinc additive and add it to the oil. I found this out a few weeks ago, and I recently comfirmed it.
67 GTX is offline   Reply With Quote
Old 08-13-2008, 01:20 AM   #2 (permalink)
cxcxcxvcvcvc
Junior Member
Quote:
Bugger thats not real good!!
Thanks for letting us know mate, will pass the word around!!
cxcxcxvcvcvc is offline   Reply With Quote
Old 08-13-2008, 04:19 AM   #3 (permalink)
Doc
MasterDebater
Doc's Avatar
Xer ... how does all this affect OHC engines? ...and what brand oil has decent amounts of zinc in it ? ... oils for diesels?
Doc is offline   Reply With Quote
Old 08-13-2008, 03:50 PM   #4 (permalink)
67 GTX
It doesn't affect OHC engines, just OHV engines.
It affects OHV engines, because the zinc coats the lifters and the cam, making the contact smoother. I have pics of what happens when there isn't any zinc added. I'd gladly pass them along, but I don't know how. Does anyone?
There is an off the shelf diesel oil that has it, but I'm gonna buy the Zinc additive. Joe Gibbs Racing along with other companies makes it.
Old 08-14-2008, 04:49 AM   #5 (permalink)
Doc
MasterDebater
Doc's Avatar
?????? ..... contact smoother ??
I thought there were issues with the lifters not rotating properly and then wiping out the cam and the lifters themselves.
I also heard that ALL syn motor oils have this "feature" tooo !! .....all this is making me think ROLLER CAM only !
Old 08-14-2008, 01:51 PM   #6 (permalink)
67 GTX
Well, you are write Doc, sorry for being a little unclear. As I understand it, roller cams don't have this problem, because of what you said, the lifters can spin.
But synthetic oil ain't great for older engines, it'll work, but not great. I'm not sure if it has the zinc in it.
Old 08-14-2008, 01:51 PM   #7 (permalink)
67 GTX
Well, you are right Doc, sorry for being a little unclear. As I understand it, roller cams don't have this problem, because of what you said, the lifters can spin.
Old 08-14-2008, 08:33 PM   #8 (permalink)
Doc
MasterDebater
Doc's Avatar
67 ..... I read an article in a PopRod mag that stated we need to look for a rating of SL to avoid these probs with the newer oils.
Old 08-15-2008, 11:24 AM   #9 (permalink)
67 GTX
ya, i heard that too
Old 08-15-2008, 10:28 PM   #10 (permalink)
Doc
MasterDebater
Doc's Avatar
I stopped off at Tractor Supply up-here and saw only ONE oil that had that SL rating ... and it was NOT their diesel engine oil.
Old 08-16-2008, 09:41 AM   #11 (permalink)
67 GTX
what was it?
Old 08-16-2008, 10:08 AM   #12 (permalink)
Doc
MasterDebater
Doc's Avatar
Just their regular oil ??.. !! .... they are going to check-that-out. Do you have one of them in your area?
Old 08-16-2008, 11:19 AM   #13 (permalink)
challenger
challenger's Avatar
Send a message via Yahoo to challenger
hey guys but im going to ask a stupid question but what does the SL stand for ? guess im not up on the oil thing but i just have always used valvoline oils and this year since im burning e-85 i went with the full synthetic syn power 20-50 --- it does have the note saying that it exceeds api services SM/SL,CF,ACEA SERVICES A3/B3/B4 and all preceding api&acea categories ? any thoughts on this
challenger is offline   Reply With Quote
Old 08-16-2008, 12:16 PM   #14 (permalink)
challenger
challenger's Avatar
hey i just wrote to valvoline about this and asked them about the little smoke i have coming out of my engine and this is what they sent
You should stay with the VR1 racing oil because it has 1300 ppm Zinc, where as the SynPower only has 850ppm, the smoke is probably due to the full synthetics detergents cleaning the engine, if the engine isn't use to full synth. the smoke could be from all the sludge buildup being burnt out of the engine...but if your looking for high zinc...stay with VR1 racing oil
Old 08-17-2008, 09:15 AM   #15 (permalink)
67 GTX
Is the VR1 oil anymore expensive than other oil?
Old 08-17-2008, 05:45 PM   #16 (permalink)
challenger
challenger's Avatar
the vr1 oil is cheaper than full synthetic but a dollar or so more than conventional oil
Old 08-17-2008, 08:56 PM   #17 (permalink)
67 GTX
I don't think I hace a tractor Supply near me. basically just auto zone and a few old speed shops. Maybe Valvoline might be the way to go, but since I have a few small leaks on my engine, I'm worried that the syntetic oil fight find them and just gush out.
Old 08-18-2008, 12:06 PM   #18 (permalink)
67 GTX
I went to a machine shop today to get my heads redone, adn he told me about an oil, which I'm not sure how its spelled, Retela T made by Shell. It has zinc in it, but he told me, it doesn't have enough. So, you need to buy the zinc additive, and pour it into the bottle FIRST! Shake it up, then pour into the car. If you don't put it into the bottle, it won't completely miz in the oil pan.
Old 08-18-2008, 10:40 PM   #19 (permalink)
challenger
challenger's Avatar
the rotela oil he is refering to is diesel oil and you do not want to use that it is formulated for the diesel engines because of the sulfer content in it, it has special cleaners for that and can harm your gas engine ... i use that in my company trucks only
Old 08-19-2008, 08:38 AM   #20 (permalink)
67 GTX
Oh, really? Wow, this zinc stuff is giving me a lot of trouble.
Old 08-21-2008, 09:21 PM   #21 (permalink)
challenger
challenger's Avatar
hey 67 just use high milage valvoline oil or there vr1 oil and you will be fine
Old 08-21-2008, 09:44 PM   #22 (permalink)
67 GTX
Oh, ok.
Thanks Challenger.
Old 09-30-2008, 09:51 PM   #23 (permalink)
67 GTX
anymore word on the subject?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
we sell edible and biodiesel oil:palm oil,vegetable oil,corn mukky General Discussion 9 08-09-2008 09:43 PM
WE HAVE THE BEST CRUDE OIL IN OUR COMPANY,BIODIESEL,JATROPHA,PALM OIL,VEGETABLE OIL,R dealerltd General Discussion 1 07-03-2008 04:18 PM
For Sale:vegetable oil,biodiesel Oil,olive oil,palm, RBD olein oilplanet Mopar Classifieds 0 03-29-2008 12:08 PM
sesame oil---USD250 per Mt soya bean oil--usd 300 per Mt sunflower oil---USD300 per robertoil Mopar Classifieds 0 01-25-2008 06:45 PM
soya bean oil--usd 300 per Mt sunflower oil---USD300 per Mt vegetable oil---USD250 robertoil General Discussion 0 01-25-2008 06:39 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
