radiator
radiator
are there any radiators that will work with a 1965 coronet? i need one but cant find one, so i was thinking of getting one off of a more common car i can find. or does anyone have one for sale?
on
If you use an oddball rad, when you install it, be sure to have a few buddies help you . they need to hold it at each end and you need to put the fan shroud on and center it on the cooling fan, this is a must. or you wont get the cooling system to operate properly. and chew the shroud up. First make sure that the hosse inlet and outlet are in the same location,. after 72. they changed sides on the bottom hose.
gotdust
07-09-2010 03:23 PM
