Sponsored by:
Sponsored by:
Transmission leak
Old 04-04-2009, 04:14 PM
sgp7679's Avatar
Question Transmission leak
I went out today and looked under my 65' coronet and saw transmission fluid on the ground. I haven't driven it in a few weeks and when it was parked the transmission wasnt leaking. It just started leaking this morning. What could cause it to leak?
Old 04-04-2009, 04:25 PM
sgp7679's Avatar
could leaving it in neutral for a couple of days cause that? i realized that it started leaking after it was left in neutral.
Old 04-04-2009, 05:19 PM
69Fury3's Avatar
Where is it leaking from? The pan or one of the lines to the rad?
Old 04-04-2009, 07:04 PM
sgp7679's Avatar
i think from the pan
Old 04-05-2009, 05:38 PM
pjmopar's Avatar
Alot of times they start leaking form sitting to long.if i were you i would replace the gasket/filter and if it is an older tranny i would reuse the tranny fluid you took out of it.Hope that works for you.We were in florida for three month and when we got home the same problem with my Plymouth.Hope that helps you
Old 04-05-2009, 06:09 PM
Crazy4Carz.Com's Avatar
Have you looked under the car???? There are "o" rings all over the trans and lines and fittings. Just get under there and look. How could anyone possibly tell you where it is leaking from?
Old 04-05-2009, 06:16 PM
pjmopar's Avatar
Sorry ,i wont do that again.Iwas just explaining what happen to my car
Old 04-06-2009, 04:47 AM
I wasn't talking about you.
Old 04-06-2009, 02:11 PM
69Fury3's Avatar
Sorry i asked a question. I certainly was not telling him where his problem was, that is why i asked.
Old 04-06-2009, 04:46 PM
I guess I wasn't clear. Sorry.
"what would cause it to leak?"
That is what i am talking about. Too much time on line and not enough under the car. Heck JUST LOOK UNDER THE CAR!!!!!
Old 04-06-2009, 06:30 PM
69Fury3's Avatar
Sorry, i guess i just took your comment the wrong way. I am not trying to come across as being cocky.
demetri
02-26-2014 07:32 PM
jerzjer
04-29-2011 03:02 PM
66coronetgirlie
08-09-2010 10:41 PM
68 Sat
04-05-2009 03:55 AM
wheelman487
01-03-2008 08:54 PM
Quick Reply: Transmission leak
