1970 Fury III Firing Order Problems
Old 06-04-2009, 03:47 AM
1-8-4-3-6-5-7-2 is the correct firing order. Are you sure that the number 1 wire was on the right spot on the dizzy?
Old 06-04-2009, 08:05 AM
ya, like tim said
make sure all of your wires went back in the correct place
Old 06-04-2009, 08:10 AM
Crazy4Carz.Com's Avatar
You have it 180 degrees off! You have number one where it is on the exhaust stroke instead of the compression stroke. I have done the same thing many times, easy mistake to make. Bring the balancer around one more time and do it again. You're close.
Old 06-04-2009, 11:56 AM
Polaradude's Avatar
X2 on that.
Old 05-05-2011, 03:59 PM
chadEmeuse's Avatar
68 plymouth sport fury
just asking what if there ant a 1 on the roder cap i know the firing order but having trouble with the cap
Old 05-05-2011, 04:05 PM
mr340's Avatar
If the distributor is not in correctly the "number 1" on the cap is useless. Bring the No.1 cylinder up to TDC and see where the rotor points, that will be number 1, then go from there 1 8 4 3 6 5 7 2 CCW.
sgcrane
10-12-2010 03:12 AM
vintagenc2
08-06-2010 02:13 PM
mack.902
07-17-2010 03:13 PM
timmie124
06-27-2010 11:05 PM
KJoeZ61
10-28-2009 12:49 PM
Quick Reply: 1970 Fury III Firing Order Problems
