1972 Brake hose?
Old 03-25-2010, 03:33 AM
Uturnrob's Avatar
1972 Brake hose?
I've replaced the drum brakes on my 1972 Satellite with spindles from a 1974 Charger. The spindles are mounted and I have the 74 calibers and disk installed. It appears that the 1974 front brake hoses are slightly to short when the wheels are turned all the way. The 74 calibers use different bake hoses than the 1972. I have the pin type spindles and calibers. Has any one performed this type of brake upgrade?
Thanks
Rob
Old 03-26-2010, 01:10 PM
69Fury3's Avatar
Not sure if the hoses are different, but a hydraulic shop should be able to make you custom length lines if need be.
68 Sat
11-30-2009 11:56 AM
opostal
10-30-2009 08:01 PM
Dust'em
04-10-2009 03:45 PM
normnovato
12-15-2007 07:14 AM
burnsy26
10-01-2007 01:35 PM
Quick Reply: 1972 Brake hose?
