318 upgrades or 360?
Hey guys, its been a while since i was last on here but i have some questions for you.
I have been doing some thinking about upgrading my stock 318 with 360 heads. Is this a good idea, what do I have to do, and would i be better off just replacing the 318 with a 360? Im trying to get the most horsepower i can.
Thanks.
Thanks.
No offence but how come you don't simply big block everything?
You guys are waist deep in V8's whereas here in the UK even 318's are scarce. I wish I had access to the supply of raw material and motors etc that you lucky people in the US have. Heck, even my lawn mower would be a hemi.......!!!
More seriously, I'd have to go with the 360. No substitute for cubes, is there..???
Shoot over to the local wrecking yard score a nice 360 for a few hundred greenbacks give 'er a freshen up and a choppy cam and "bob's your uncle"
Terry.
Terry.
there are some dis-advantages to doing that
if you are only looking for 400-500 hp, the small block can do it, and you save a lot of wieght
it is also easier to swap if you have already have a small block
With swapping to a larger small block, you can just bolt it in and go. With a big block, you'll need a tranny, torsion bars, frame tie-ins (if looking for big HP and torque), a lot better cooling, etc.
I'm not nit picking and I don't pretend to have much knowledge about MoPars in particular but since there's a possibility that I might want to one day get more power from my Plymouth Fury than the 318 currently residing under the hood provides, I'd like to know as much as possible before I look at options.
It seems to me that the 450Hp mentioned here might be quite pricey to achieve with any SBM not to mention that it would probably result in a motor with very few street manners and the TorqueFlite behind it would probably not survive for very long requiring a change of tranny to its bigger brother or some fairly serious modification and uprating. And how many SBM's REALLY make a GENUINE 450hp ??
With that in mind surely it would be cheaper, easier, more streetable and quicker to simply fit a 440 suitably modded to make 450hp -especially knowing that you'll have a much more civilised and possibly more reliable motor under the hood.
In good old Limeyland we have a slight bit of luck in that the British sports car, Jensen, was fitted from the factory with a MoPar V8. Many of these were BB and a few even had a six pack. These pop up every now and then online and are a nice alternative to the usual RV cut-outs that are often floating around over here.
Raindance654 - You are right, going with a BB to get that 450 number would be easier and maybe cheaper than building a SB. It's all up to the owner though. It all depends on how much work they really want to do though.
I dont know but I'm not seeing an excess of Big Blocks in the wrecking yards lately. The occasional 400 once and a while. I do see a lot of 360's though. [thats what im putting together now]
my 2 bobs worth
i will only go with what i have done & am doing . on the cheap i would go with a 360 for stock power up grade . now there are many stroker options available for the 318 & 360 . but give me big block rods , bore & stroke oil system , bearing size , valve size , reciprocating weight ( torque ) bullet proof 727 ect ect any day of the week . as soon as you spend money on machining it doesn't matter weather it's sb or bb it costs the same . hell the price of a 383 with 727 over there is insanely cheap compared to what me & raindance would ever see . I'm very happy with my 383 & a lot of people say to me thats sb cid , well look at my rods , bore & bearings & how hard it rev's DURABILITY is the name of the game . i was reving my cammed up stock 383 (hyd cam ) to 7000 rpm in 2nd gear . sure i bent a push rod & hyd lifters aren't meant to do that but it's a very good sturdy base to start with . & any of yous who have read about all the problems i have had , i can tell you i have learned the long hard way , but it's all part of the journey i never owned a V8 till i bought my 318 Ute & i had no intention of being a car nut , but v8s change people . my cammed up stock 383 was making around 400 hp ( 270 + rwhp ) 1250 lbs of torque @ 2800 rpm & i had a 3000 stall . i only had 5.8-6.1:1 compression @ the time also . my engine was so miss matched & still made good power . i am now out of work & on the tightest of all budgets & am making do with what i can just now but my lil 383 will be making some very good hp I'll keep yous posted . conclusion go 360 if staying small block . BUT BIG BLOCK IT 4 THE HELL OF IT .
P.S. If you ever hemi your lawn mower I WANT TO SEE IT!!! And drive it lol
69POLARA383
01-11-2012 07:38 PM
