440 big block, vent pcv hose and cap on the carb?
Old 04-19-2011, 11:09 AM
1923tbucket's Avatar
What im doing is installing a oil catch can in the PCV line. Would it be ok to run my pcv hose to the can and just vent the can to the atmosphere or should I run a line back to the carb?
Old 04-19-2011, 02:23 PM
John Van's Avatar
What are you trying to accomplish?
The catch can should be installed in the line between the pcv valve on one valve cover and manifold vacuum, with a breather on the other valve cover. If you are getting oil out of the pcv valve make sure that valve cover has a baffle under the opening for the pcv valve.
john
Old 04-19-2011, 10:35 PM
Yea the valve cover has a baffle in it, still drips a bit of oil and makes a mess all over my intake manifold and in turn blows all over my windshield. I know when I ran boost on my other car me and a few others just ran a breather on the other end of the catch can instead of running a line back from the can. With boost theres enough crankcase pressure so.
josehf34
03-08-2014 08:26 AM
ZombiePopper
01-06-2014 08:34 PM
Shrug
04-30-2013 12:40 PM
1923tbucket
06-22-2010 09:14 AM
dwf
03-28-2009 11:43 AM
Quick Reply: 440 big block, vent pcv hose and cap on the carb?
