727 transmission rebuild Q's
Old 10-31-2008, 05:42 AM
Is the 440 built up at all? What goodies are on it?
A shift kit, stall convertor (depending on the power of the 440), and a really good rebuild kit installed by someone who knows mopars really well will do you wonders.
Old 11-01-2008, 06:45 AM
As far as I am concerned, B&M is the best (parts wise) for mopar trannies. For new trannies, I would only go with TCI.
Old 11-01-2008, 01:18 PM
Commando's Avatar
Is this the kind of kit you are referring to: http://www.bmracing.com/s.nl/c.72308...it.A/id.354/.f
I think with what I am doing to my 440 I have to identify any possible weak links so I would like some more info on the stock 727 trans.
Old 11-05-2008, 01:44 AM
for in city driving and strip that would be a good stall speed, but if your planning on taking the car onto the highway, then I would look for a little lower stall rating. probably 2000 to 2200 RPM.
Old 11-05-2008, 06:04 AM
Commando's Avatar
what is the stock stall rating?
Old 11-05-2008, 07:11 AM
I think they range from 500 to 750 RPM. Put your car in gear when its running and have it on a flat area. Let your foot off the brake and see at what RPM you start moving. That is where the torque convertor is kicking in and having the tranny move the vehicle.
Old 11-06-2008, 02:58 PM
Commando's Avatar
So I started looking at converters and TCI seems to be a popular brand and their Saturday Night Special seems to do what I want, anyone have any opinions on them?
I also noticed that they sell ones with weights on them which they say are used to balance the cast crankshaft, but I replaced the 1977 cast crank with a 1973 (I think) forged one (steel), so do I go for the unweighted stall converter? Are these cranks balanced on the flexplate or not at all?
The picture on their website shows teeth on the converter where as Summit shows it needing a flex plate, anyone have the answer to that?
Old 11-06-2008, 04:46 PM
Commando's Avatar
I have not done anything yet, the engine is still sitting in the machine shop waiting to be picked up.
I am trying to figure stuff like this out before it becomes an issue, so I need to get a regular flex plate as I will be using a non-weighted stall converter? TCI has two different types of flexplates ones with 5/16 bolts and ones with 7/16 bolts, I assume this for the crank?
Old 11-06-2008, 05:36 PM
BuckNeccid's Avatar
A better way of checking for the stall of the convertor is to put it in gear, put your foot on the brakes and then nail the throttle for a second. The max RPM you see on your tach before the car starts pulling is around the stall. They are designated to be the point where the engine torque overpowers the fluid and begins transferring the energy to the transmission. The more torque your engine makes, the higher the stall will be, even if it's factory rated at say 2200 rpm. If you're driving normally, it won't "flash" to the stall point, it will start pulling sooner than that. It's sorta like a clutch... if you feather a clutch in, it will start grabbing at a lower rpm than if you rev the engine and just dump it. The stall effect is like dumping it.
sirus444
07-05-2009 09:17 PM
MrMopowered
05-09-2009 11:31 AM
Commando
01-01-2009 10:29 AM
hubcap
05-06-2008 06:26 PM
ucfierocharger
08-04-2007 07:37 PM
Quick Reply: 727 transmission rebuild Q's
