AC Compressor Size?
Old 03-03-2011, 05:12 AM
fastdakota84's Avatar
AC Compressor Size?
Does anyone know how many cc's an older piston type AC compressor is? Such as one off of a 1976 Chrysler New Yorker?
Thanks
Old 03-03-2011, 07:44 AM
samuelcosmo76's Avatar
I know mine took (4) 12oz. cans of refrigerant....if that helps at all.
Old 03-07-2011, 06:29 AM
Well, I was just wondering if anyone knew the size of the actual compressor (cubic centimeters (cc)).
Old 03-19-2011, 03:13 AM
ddunk80's Avatar
Thanks
Vehicle designers typically will note the total ac system oil requirement on a vehicle or compressor sticker or in a manual, and measured in fluid ounces or cc’s. Too little oil will cause a ac compressor replacement to lock up while too much oil will coat the evaporator and condenser walls reducing heat transfer.
Old 04-08-2011, 03:02 AM
Are you converting to R134a ? do you have a vacuum pump & gauges Unless you have the proper gauges ? Have some one do it. Fill amount is critical with the conversion. You may need to remove the AC dash vacuum switch and reseal it. They were good for vacuum leaks
ritroutt
05-24-2015 06:14 PM
S.Q.U.I.D
11-01-2013 08:08 PM
koondawg_74 roadrunner
09-08-2013 08:53 PM
Valex9499
02-27-2010 12:49 PM
cowvette
03-07-2007 08:24 AM
Quick Reply: AC Compressor Size?
