Drum Brake Spring
Old 12-15-2008, 05:10 PM
challenger's Avatar
I have no idea, cant say that i have ever seen one out side of the drum ??? what did you connect it to
Old 12-15-2008, 05:13 PM
challenger's Avatar
now im thinking !!! is it the one that is wraped around the drum ???? if so i think they used to use them as something to do with the vibration or something
Old 12-15-2008, 07:21 PM
I think it has to do with disipating heat or something
Old 12-16-2008, 01:02 PM
my car has it too
im not to sure on what it does
Old 12-16-2008, 03:29 PM
Senior Member
ef8340's Avatar
hi guys
that spring is a anti-chatter/vibration spring
hope that helps
Old 12-16-2008, 04:21 PM
challenger's Avatar
Thats what i think also if i remember correctly but if you were to buy new ones i dont think they have them on them anymore ?
Old 12-16-2008, 05:47 PM
Originally Posted by ef8340
hi guys
hope that helps
i never would have thought that
Old 12-17-2008, 01:27 PM
Not sure. Cars today don't have them, so they may not be necessary, but I'm not sure.
Old 12-17-2008, 05:33 PM
challenger's Avatar
Take the springs back off and throw them in the steel pile
Old 12-18-2008, 12:50 AM
rr69half6bbl's Avatar
If you got the new drums from auto zone, theyre the china pcs. that mopar muscle mag was talking about a few yeasr back. they are junk, they have a bad habit of getting hot due to the thin walls of the drum sides, and they arent perfectly round, they have an oval shape to them causing them to over heat and then warp after a short life cycle. then you cant turn them due to the thin layer of lining. I had a pair. ended up paying twice the price for new napa , made n usa pcs. just be carefull. they have a real bad brake fade to them as well from over heating.
Old 12-18-2008, 04:15 PM
smackhonda's Avatar
that spring is there alot of the time for when the person is turning them at a shop. What is does is absorbs the vibration waves so the cutting tool leaves a nice smooth surface, if its not there while they turn the drum it will leave a rough surface
motorcitymopar586
09-28-2013 12:12 PM
Old Rider
11-19-2011 10:40 AM
Mike66Newport
05-13-2011 06:24 AM
Bossta
10-06-2009 09:56 AM
jar84203
08-18-2009 08:21 AM
Quick Reply: Drum Brake Spring
