Go Back   Mopar Forums > GENERAL > General Technical Questions
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-14-2008, 05:42 PM   #1 (permalink)
Mixmastermerrill
Member
Mixmastermerrill's Avatar
Question Hack and sputter
I started my engine for the first time today and it runs great untill I pull it past 2000 rpm's. Thats when it starts hacking and sputtering. I thought it might be timing but that is correct so I am at a loss.
"1976 Chrysler 360 In a 1974 Duster"
Any suggetions welcome.
Thanks
Mixmastermerrill is offline   Reply With Quote
Old 08-14-2008, 08:44 PM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
Fuel pressure ?
Doc is offline   Reply With Quote
Old 08-15-2008, 12:37 AM   #3 (permalink)
Mixmastermerrill
Member
Cool! I’ll check that out. I was also told that it could be a sticky vacuum advance not advancing as I accelerate. Is this true?
ALSO, could it be a bad block to body ground? I used the old grounding strap that was in very poor condition.
Ill check out all these issues tomorrow. But, if you could still correct me on my other theories.
Thanks for all the info Doc.
Old 08-15-2008, 06:47 AM   #4 (permalink)
Doc
MasterDebater
Doc's Avatar
The VA will not "work" when you are accel ! ... it only comes in on lite throttle.
A bad ground could be a prob too. A bunch of star-washers are a help there !!
Old 08-15-2008, 06:13 PM   #5 (permalink)
Mixmastermerrill
Member
OK, the fuel pressure is good, the Grounds are good and the timing is correct. It's still sputtering at 2000 RPM. It also backfires a little through the tailpipe when I let off the Gas or give it gas past 2000 RPM.
Thanks
Old 08-15-2008, 10:33 PM   #6 (permalink)
Doc
MasterDebater
Doc's Avatar
Weak spark ? ....coil ? ???
Old 08-15-2008, 11:06 PM   #7 (permalink)
challenger
challenger's Avatar
Check to make sure you have the right spark plugs and that they are gaped right and check the distributor also check to make sure your plug wires are pluged in all the way but i would lean to your plugs at this point
challenger is offline   Reply With Quote
Old 08-15-2008, 11:12 PM   #8 (permalink)
challenger
challenger's Avatar
P.S what carb are you running ?
Old 08-16-2008, 12:27 AM   #9 (permalink)
Mixmastermerrill
Member
It's a Edelbrock 650
Old 08-16-2008, 10:02 AM   #10 (permalink)
Doc
MasterDebater
Doc's Avatar
Mixer ...what three things do you need to have an engine run ? ..... compression, fuel and spark.
Compression is a given(it runs fine at idle), fuel(is checked out) .......
I say SPARK is the problemO !
Old 08-16-2008, 03:24 PM   #11 (permalink)
Mixmastermerrill
Member
Cool I'll make the rounds
Old 08-16-2008, 05:03 PM   #12 (permalink)
Mixmastermerrill
Member
I am showing 11.8 V out the main coil to cap wire. The bat is showing 12.6 V. What amount of Volts should I be showing through the coil to cap wire.
I also checked the coil pos feed wire and its showing 10.5V. Is that a problem. Not sure what I am looking for.
Thanks for any info
Old 08-16-2008, 05:29 PM   #13 (permalink)
challenger
challenger's Avatar
is the neg,,- wire from your coil going to your distributor ?
Old 08-17-2008, 02:49 AM   #14 (permalink)
Mixmastermerrill
Member
No, It is coming from the ECU. The Distributor is electric. Not Points. 1976. The + on the coil comes from the ECU through a ballast resistor to the + coil. I also have a swich in the car for the main power feed to the + coil.
thanks
Old 08-19-2008, 12:42 AM   #15 (permalink)
Mixmastermerrill
Member
Well, I gapped the distributor pickup and it will rev to 3000 rpm. Unlike before at 2000 before it starts sputtering. I purchased a new dist. pickup. Wrong one! No others in the state. Will need to wait till next week to test it out. Dang!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
