How do I remove the steering coupler from the steering gear.
Old 04-10-2010, 12:35 PM
Junior Member
cvon's Avatar
I'm new to this mopar forum and need assistance removing the steering coupler from the manual steering gear of a 69 roadrunner. I've managed to remove the steering column and wheel from the car but would like to disassemble the steering coupler from the manual steering gear. The lower pin is out and you can see clear to the other side through the hole. It still does not pull off. Does it screw off? How is it removed at this point? help?
Old 04-10-2010, 03:44 PM
Welcome to the forum!!!! How about some photos ????? We would love to see your ride.....
Old 04-11-2010, 04:49 PM
Junior Member
cvon's Avatar
Thanks I will give it a try. Is there a pulley that I can buy to pull the coupler off, if this does not work?
Old 04-11-2010, 04:51 PM
Junior Member
cvon's Avatar
Sorry this car was a michigan survivor that was disassembled because of severe rust. I was taking apart the steering column components so that someone else could possibly benifit from its donor parts.
Old 04-12-2010, 05:47 AM
Junior Member
cvon's Avatar
OHD,
The coupler moved 1/8 of an inch with the heat and then stopped. As I mentioned in the above thread there does not seem to be a pin in the hole at the bottom of the coupler. I can put a nail in the hole through to the other side. It's still not moving. Is the pin that holds it on the gear hollow or solid? I never removed a pin from this location, it has always been hollow.
Old 04-12-2010, 09:49 AM
rdrunner1974's Avatar
coupler pin
Use a punch 3/16" diameter and drive the pin out. It is hollow, often called a roll or spring pin.
Paladex
05-18-2014 05:40 PM
cuda341
03-06-2014 03:12 PM
TRAMO
01-19-2014 03:27 PM
Sean Griffin
04-04-2013 08:25 PM
olibass1
04-22-2011 07:10 AM
Quick Reply: How do I remove the steering coupler from the steering gear.
