I need help
Old 06-06-2011, 08:54 PM
matt93's Avatar
I need help
I plan on buying a old dodge and was looking at a crate 360 motor
http://www.rebuilt-auto-engines.com/...17111397376.35
this is the one i was looking at is this a good motor and what else would i need beside intake,oil pan, valve cover
Old 06-06-2011, 11:25 PM
Timing cover, water pump, Flex plate.. headers/ manifolds
USE a standard oil pump !!!! elect distributor
A bunch of bolts & accessory pulleys
Old 06-07-2011, 05:26 AM
matt93's Avatar
Thanks for reply it really help me out but i have a question about the the bunch of bolts. what type of bolts would i need and is that a good crate motor to buy?
Old 06-07-2011, 02:40 PM
John Van's Avatar
Matt,Please tell us about the car you plan on buying.Does it come with a motor?
john
Old 06-07-2011, 07:31 PM
matt93's Avatar
I am mainly looking at a dodge d100 to buy between 1970 and up, but a car would be nice but to much money. I found some d100 at a decent price and most of them had a v6 but would putting a 360 in be a good idea. My main purpose is to have a truck that can be driven daily and have some power also
Old 06-09-2011, 10:53 PM
Mopar_71's Avatar
You are better off buying an original V-8 truck instead of a slant 6 truck if you want to put a 360 in it.
Why? Because you will have to change the K-frame or buy a slant 6 to V-8 engine swap kit. You will need to change the transmission to a smalll block V-8 type transmission. Change the driveline, rear end, get a bigger radiator, and buy tons of other parts needed to reconfigure the slant 6 truck to a v-8. $$$$$$
Trust me. I learned the hard way converting a slant 6 car to V-8.
To answer your original question about the motor, I would NEVER, EVER, EVER buy a motor online I couldn't see for myself. And since 1974 spec engines didn't have as much horsepower as earlier 70's engines, I'd buy a decent 60's - 70's motor that needed to be rebuilt and take it a shop that will warranty the work.
Just because they advertise something online doesn't mean you will get what you pay for. Then you will be stuck with it.
Check out this website regarding the motor you are looking at. This is the company that remanufactures it. I'd say these guys find a 360 motor, clean it and send it. Without tearing it down and rebuilding it.
If you choose to buy, make sure it's with a credit card so it can be disputed.
http://www.bbb.org/eastern-washington/business-reviews/engines-rebuild-and-exchange/s-j-engines-inc-in-spokane-wa-5000611/
Good luck!!
Old 06-10-2011, 03:50 AM
X2
Starting off with a truck that already has a V8 in it will be much easier. Also, if you want a 360 to use as a DD and have some power, I would just go fo a Mopar crate motor that is already built. Most of the time all they need is a carb, headers and dizzy and are already putting out 300+ HP and torque.
Old 06-15-2011, 10:45 AM
69POLARA383's Avatar
I have a 383 for sale...needs fuel pump, alt, push rods, carb and intake but its been hat tanked, sonic tested, magnifluxed, bored .30, steel crank turned .10, alum flat pistons, 452 heads, new bearings kit, new pins & rings, new freeze pluigs, hp oil pump, new double roller timing kit, purple shaft cam...very strong solid motor. 69 block from road runner, have pics
Rumblefish318
06-30-2013 12:56 PM
73plymduster
08-15-2010 10:21 AM
Quick Reply: I need help
