Just a game
Old 05-12-2012, 06:33 PM
Mr.4spd's Avatar
Just a game
I figured this one out two years ago, but I thought I'd post here and see what you guys would have done.
"My car starts and runs great. The problem is that it stalls about half way through third (when I'm beating on it). Then I lift and it comes right back. It started doing this off and on recently. It's a B/RB 4speed car"
Ok, it took me two steps to figure this one out, shoot me your best two guesses.
Old 05-12-2012, 10:34 PM
Fuel pressure ???
Old 05-13-2012, 06:16 AM
Mr.4spd's Avatar
Right? So I replaced the fuel pump with a new Holley high output. The problem returned after a few weeks. So now what? Oh, and the fuel tank and pickup are only a few years old, and the filter is clean.
Old 05-13-2012, 03:23 PM
gunnerman's Avatar
vacume?
Old 05-13-2012, 04:33 PM
Mr.4spd's Avatar
Vacuum is good. I was expecting more responses on this. Even if your responses aren't right, I'd still like to hear some ideas.
Old 05-13-2012, 04:36 PM
Sorry I don't have time to play "this game."
Old 05-13-2012, 06:25 PM
Mr.4spd's Avatar
Sorry for wasting your time, 440. You can go back to your game of hopscotch now. Jesus, I didn't realize this forum such serious business.
Old 05-13-2012, 06:40 PM
PK1
PK1's Avatar
1. Vacuum secondary's? Leaking diaphragm? or binding linkage?
Did the new FP really fix it? Or did you not beat it appropriately ?
Old 05-13-2012, 08:27 PM
People don't really like guessing games unless they are going to win some . I would just add a poll to this thread and give us a couple of choices to vote on and then tell us at the end of the poll.
Old 05-14-2012, 03:26 AM
Mr.4spd's Avatar
It was the fuel pump pushrod. Can someone now explain to me how I can get paid when I guess an answer to someones problem. This is apparently very serious work here. See, I have a job and this is just for fun for me. Sorry for wasting anyones valuable time.
Old 05-14-2012, 03:28 AM
What was wrong with it? Bent? If so, wouldn't it have caused an issue all the time or at least every time you hit a certain RPM range?
Old 05-14-2012, 05:12 AM
62Furious's Avatar
Some of us would like to know, was the rod worn bad on the cam that it would not build enough presure
Old 05-14-2012, 02:39 PM
Mr.4spd's Avatar
The pushrod was worn 3/8" on just one end, it was weird. What was happening, was by half way through third the float bowls were empty because the pump arm wasn't being cycled far enough. I bought a new one from Mancini and haven't had a problem since. As I understand it this is an uncommon problem. And I wasn't paying attention when I pulled it so I don't know which end was worn.
Old 05-14-2012, 08:07 PM
gunnerman's Avatar
i find this info good to know. thanks for letting use know. not something you see every day.
Old 05-15-2012, 09:39 AM
I had this happen to me recently too. I suspect mine wore due to wear. The lobe on the cam was fine so that is how I arrived at that conclusion.
Old 05-16-2012, 07:44 AM
I was afraid to guess until someonelse took a stab. I thought maybe you missed the clutch and hit the emergency pedal, or maybe forgot to switch the computer to "race mode" thank goodness it wasn't the Turbo Incabulator, those things are an arm and a leg.
Joking aside, always good to get information that may help another Mopar lover, no matter how it comes along. Thanks.
Old 05-16-2012, 12:59 PM
Mr.4spd's Avatar
The turbo incabulator film is hilarious. And I forgot to mention that the headlight fluid was low, so that might explain it too.
rcknrolfender79
10-20-2012 10:42 PM
dadof3byz07
01-16-2011 05:27 PM
maxaud
09-23-2010 07:34 PM
deadkelly
12-22-2009 06:47 AM
79mopower
11-13-2006 08:08 PM
Quick Reply: Just a game
