knock/ping when i let off the throttle
360 small block crate
it will make a ping/ knock sound for 3 seconds then go away
sounds like a backfire almost comes out one side of engine.
thanks for the help
thanks for the help
Good advice. I would also check all timing events with a light to know what I'm dealing with.
Knowing initial, mechanical, vacuum advance and at what RPM's they occur will help wih solving the current problem and any future troubles if you get into bad gas.
If you run vacuum advance.......................
"All carburetors" don't have the same ported vacuum "kick in" characteristics. That is, even if you had timing and advance curve, and a vacuum can that was close, it might be that the carb vacuum might be coming in too soon.
I used to have this trouble with a Q-Jet on a 340 "back when."
This was the problem. There was a loose header fastener... Using a crush gasket caused the fastener to be too short and semi strip out.
Found a engine shop they said they can fix it better than using a HELIO COIL.
thanks for the help!
RacerHog (11-21-2013)
felipec2106
12-04-2014 03:09 PM
PK1
12-29-2011 07:04 PM
