need help to figure out why a dodge neon wont go to reverse
Old 03-13-2009, 09:10 AM
There is a silnoid pack on the front end that could be causing the problem. Are there any leaks? How does it shift? is it clean, fast, smoot or does it slam into the next gear, takes higher RPMs before it shifts?
Old 03-13-2009, 10:56 AM
blue 68 gts's Avatar
My guess will be reverse is toast inside the trans.
I just pulled out an automatic trans from a 98 Jetta that had the problem of REVERSE working, but no forward gears. The whole clutch pack was toast. The sprag was in a million pieces within the trans.
Old 03-13-2009, 11:12 AM
Well, I'm not sure exactly what year the Neon first came out, but 1) it needs to be an OBD2 .
Secondly, you'll need to replace it with more then likely the same type of automatic transmission seeing as how the ECU and rest of the computer has to match.
Just because a DIFFERENT transmission will bolt up, doesn't mean it'd work, unless you change all the programming, and wiring harness, ect.
Hope this helps.
-nick
Old 03-13-2009, 11:58 AM
Throw in a known good tranny that is the same as what is in there if you are going to replace it.
Old 03-13-2009, 06:18 PM
You can do anything you want to.
It just all takes money. And time. Mostly money.
You start with the swap, then realize that you need a wiring harness, then you realize you need this, then that, then you have to get a new driveline, then you need to fabricate this and that.
I'd just find another transmission that is the same year, same style to put in it, IF i could fix why it wouldnt go in reverse first.
-nick
Old 03-24-2009, 11:36 AM
Senior Member
craveman's Avatar
best bet is to put it back in the cracker jack box and bury it somewhere you'll for get about it
Old 03-25-2009, 03:05 AM
mr340's Avatar
You need a transmission, plain and simple. You can find 1gen neons in every J/Y. You need to use a 2 gen transmission, depending on the year, I believe they are all the same except for the '95. 96-99 should all work for you.
Old 04-18-2014, 09:13 AM
Salvador Ibarra's Avatar
1995 neon
I have a 1995 neon, the issue I have is that when it's in drive. It moves forward just bearly but does the same thing when it's in reverse. yes also forward. Can someone help me?
74Runneer
01-11-2015 01:20 PM
betweentheframe
08-28-2010 04:38 PM
recondotexas
02-06-2010 10:39 AM
v8only
06-30-2009 08:41 AM
reallylongnickname
09-11-2008 04:28 AM
Quick Reply: need help to figure out why a dodge neon wont go to reverse
