318 questions
318 questions
I am trying to fit a 318 engine into a 35 plymouth. It was in the car when I got it several years ago but it needs to be repositioned to work correctly. Can someone tell me how many different motor mounts were used on the small blocks. I have to make new frame mounts and thought maybe there is a mount that might work better. The ones I have now use a single long bolt that goes through the mount and frame brackets. Is there a motor mount that has a single stud that goes into the frame bracket? It may be easier to fab some frame brackets that use a single stud. If there is, what kind of vehicle used them.
You could try a frame mount from a 70s pickup…
Thanks for the response. This is an LA engine. The mounts on the Mancini site may be just what I need. Fabricating brackets to fit those should work out better. I will have look at the 70's truck mounts to see how those will work.
Motor mounts
I bought a 40 plymouth with a 340 already installed. If you are using an updated rear remember to offset the engine to match the input shaft on your rear so you don't have an unfixable vibration.
