318 Runnin Rough...
Old 10-25-2014, 06:10 PM
  #31
Gorts 5th's Avatar
Smile
Originally Posted by Robert Weaver
Cast # on the block says its a 318 poly, the heads were 318's too. The vin says it had a 360 2-bbl.
If I understand correctly you have A Polly 318 with a 360 LA 2bbl. Intake manifold on it ? That doesnt fit....
and befor the head work done this ran ? well ?
Or did you get the head work done to make the intake work?
The 318 heads 2bbl. Will not match up smoothly at all with a 360 2bbl
The size diffence is too great.
there is a reson they have both 318 ..360...specific maifolds 2bbl. 4bbl.
and this holly 2bbl carb is not calibrated for your 318 ...if it came on that 360 manifold off a 360 engine .
you have to be more accurate in your part specific combo..
I have tryed these combos years ago beleve you..me..
You may have a maifold leak...at the heads let alone the ports dont match/aline.
the carb if off a running 360 will not drop on a 318 without tunning...and if its the 2bbl. Holly I think it is tunning it will be next to imposible ..lack of tunning parts.
Old 10-25-2014, 08:46 PM
  #32
Robert Weaver's Avatar
At one point it did run decent without missin or anything. I've been fighting electric issues ever since though. I don't know why someone put this odd combo in the car. Here's the cast #'s
My 1974 Charger SE Baby Blue White Top
VIN # = WP29K4A170230
Block Cast # Driver Side = 2532630
Head #'s = 2843675
Manifold # = 3698437
crash
03-08-2013 06:54 PM
77Adventurer
13
08-29-2012 10:23 AM
DigitalDirt
08-28-2009 10:55 AM
68satellite
05-18-2009 06:25 PM
sgp7679
04-25-2009 11:44 AM
Quick Reply: 318 Runnin Rough...
