5.9 magnum head crack between valves
Heads were a defective from factory in my opinion. If you have them you can get rebuilt ones from Clear Water Cylinder Head for short money. A lot cheaper than trying to repair then. I doubt they are only cracked in one spot.
302 wont fit with magnum valve train.
The carb should be fine. Will need to be tuned to your application.
The last 3 magnums I took apart, Jeep, Dodge truck and from some car all had the valves pounded in. Not a thing was salvageable with the head. The one block we're using with LA heads and external shaft oiling we made up.
Engine Quest makes a really good affordable Magnum head replacement.
http://www.aamidwest.com/enginequest...r-magnum-head/
Check Ebay for the cheap cheap deal.
Laura Cullen Reynolds
04-22-2024 03:24 AM
cudaracer
01-07-2020 12:50 PM
