79 Dodge back firing
on
My 79 D100 pick up with a 318 and holley 650 backs fires when I accelerate hard. When I drive normal it doesn't do it. It does it for a while then it doesn't do it for a while. Could it be carburator or timing? Any imput will be appreciate.
on
I feel it in the exhaust. Its weird, it was doing it a lot when I step on it, it would back fire bad, as soon as I back off on the accelerator it would go away, then it stopped doing it for a while. Now started back up again. It almost feels like, when the secondaries open up, that is when the back firing starts. On a side note, a couple of times I had problems with the secondaries staying wide open and had to shut the truck off to giggle the mechanism that the secondaries sit on to get them to close. So I was thinking carburetor.
if he s getin a back fire out the tail pipe its to advanced the.. timing. what might be happening is your vacuum is hooked up to a port that is advancing it to quickly and causing the tail pipe back fire but also if your secondaries are sticking open thats a red flag for a bad or incorrectly modified carb could be all your problems you have a few things to check
i know you can get a carb kit from any aouto paarts sorte in your area. as for who could rebuild it for you i would call around some of your local shops or try to find out if one ofour members here know how to do it that may live close by. i do all the carb work on my car myself. it's not that complicated as it may seem. just be sure to take your time and tey to remember what went where.
vintagenc2
08-06-2010 02:13 PM
