aluminum head corroded stud
got a budi with a aluminium head, Nissan exterra his family car with a broken intake stud, broke off in it ...it's the typical corrosion you get when mixing metals like that .
his mechanic has, "probably not certified" has tried heating it reattaching a head on the bolt and it wont come out he's going to attempt to drill it out, but already dulled 2 carbide bit's. i'm trying to get pic's haven't seen it he's just trying to describe it to me,
what are your suggestions on how tow get it out
the head is on the motor it was pulled for a supposed head-gasket failure.
our tried and true was to heat the head or block with a propane torch, and hit the bolt with r 12, now today...134 a it works for us
how would you get it out?
Yep... One works the drill, the other squirts the oil to keep it cool. Try going very small on the first bit and make a relief hole. Then walk the thickness in. As you get close to the threads try a dental pick and some times you can get the bolt thread out as pressure has been relieved by removing the inside diameter.
Dominic Torreto
10-11-2012 09:10 AM
