Bent pushrods?
Hey ya'll,
Wondering what can bend a pushrod? The motor is a poly 318. All the pistons are fine, camshaft looks like it has normal wear and the no metal found in the oil pan. Any ideas? T David |
If the valves adjustments are in-correctly set, that could do it.
Were the push rods that bent original? If not, someone could have replaced them and maybe didn't take the correct measurements. |
Bounce on the stem from a loose rocker nut, over revving it, retainer to guide contact?
timing chain
