Bolt Torque Question?
Old 09-23-2014, 02:11 PM
Robert Weaver's Avatar
Question Bolt Torque Question?
On my SB LA 5.9 360 motor, haynes manual says 95 ft lbs for the Head Bolts?
Is the Rocker Shaft bolts the ones in the middle of the shaft?
Old 09-23-2014, 03:40 PM
I'll say yes.
Head Bolts 3/4" socket.
Rocker Shaft Bolts 1/2" socket.
Old 09-23-2014, 07:31 PM
Yes, and some of the manuals are wrong. Go by the size and grade of the bolt
a 3 pointed Y on the head means "grade 5". Most these are 5/16 grade 5. If memory serves, 15 ft lbs, NOT 30 for the rocker shafts
Old 09-23-2014, 08:02 PM
Oops memory, the correct amount is 210 in/lbs.
Old 09-23-2014, 08:23 PM
moe7404's Avatar
if i remember right. the small blocks has 4 bolts around each cyl. with the dia 1/2-13. torque 85 ft lbs. and big blocks have 5 bolts. with dia 7/16 at 70 ft lbs. and the 15 ft lbs for rocker shaft bolt of 5/16-18 is right for the small block. and big block rocker shaft bolt 3/8-16 25 torque. all this from a 1967 coronet factory service manual.
66dartvert
12-04-2016 02:21 PM
ralphr87
09-25-2012 09:53 PM
Red Devil
20
04-18-2011 06:05 PM
chlngr1970
08-12-2009 12:16 PM
JLanzino
02-27-2009 09:38 AM
Quick Reply: Bolt Torque Question?
