Cam questions 318 magnum
#91
I use a ECU Microtec M24 is italian ECU
I will change the spark plugs and then let's calibrate the ECU correctly
let's see what we can do
will update later...............
thanks
thanks
#95
Sorry I'm late, but I always have little time ....
We were able to fix the problem, now all right just needed a good set up of the ECU, we made 350HP I was hoping for more.
I still use the original heads, which I could mount heads?
How much HP gain performance with other heads?
Kadassa
07-02-2014 06:26 AM
