which carb gasket do i need?
hello guys, im running the edelbrock torquer intake on 440, the single plane one, and a 3310 series holley carb, which gasket do i need to use for carb to intake?
open bore or square bore gasket?
the intake is wide open. the carb and the four openings on the bottom of the carb are of equal size/spacing.
thanks?
thanks?
Use the open plenum gasket on the intake. If you have hood clearance, use a spacer. a four hole spacer for better torque and drivability or the open for more mid-high end power.
john
john
rcknrolfender79
09-01-2015 07:42 PM
Moparknighthawk
05-22-2010 09:10 PM
