Correct Torque Setting for Intake Manifold BOLTS ON 6.4L ?
Old 04-28-2015, 10:37 AM
JETBLU's Avatar
Anyone know the propper torque setting for intake manifold bolts on the 6.4 engine (2011 Challenger 392)? I posted this question elsewhere, & I get replies (guesses) from some well-meaning guys ranging from 105 in.lbs.... to 210 in. lbs.
Maybe someone who has a Service Manual can check & let me know for sure.
Would appreciate it! Thanks!
Old 04-28-2015, 01:10 PM
Drag Pak's Avatar
Here is one answer. At 106 lb.in. It isn't very much more than "Careful or you'll do harm".
http://www.justanswer.com/dodge/4ngm...-6-1-hemi.html
Old 04-28-2015, 01:12 PM
JETBLU's Avatar
Originally Posted by Drag Pak
Thanks, but that's for the 6.1. The 6.4 is a different intake...spec is probably different.
Old 04-28-2015, 01:20 PM
Drag Pak's Avatar
They are the same size bolts 5.7/6.1/6.4!
Old 04-28-2015, 01:25 PM
12 NM or 9 Ft Lbs.... That from ProDemand As of 5 min ago...
Old 04-28-2015, 01:28 PM
Drag Pak's Avatar
Bob, that sounds just like 106 lb.in, lol.
Old 04-28-2015, 01:33 PM
Hahahahahahaha.... I did not go out that far..
Thanks for the conversion....lol
Old 04-28-2015, 01:34 PM
JETBLU's Avatar
OK, Cool! Thanks guys!
Old 04-29-2015, 07:08 PM
Don't try to do it with your ft' lbs torque wrench USE an in" lbs wrench
JETBLU (04-30-2015)
Old 05-01-2015, 11:03 AM
Rooty's Avatar
I'm assuming Bob's going by the "manuals" nomiclature and he's right on - 9 ft. lbs. but 10 won't hurt either.
Old 05-01-2015, 04:05 PM
Yes...That is rite out of the Manual... No B.S.
Caravandalism
08-16-2012 07:10 AM
kartman48
07-01-2011 06:49 PM
nitrosdog
12-17-2010 11:41 PM
beep1969
12-19-2009 03:16 PM
M1 Manifold
05-21-2009 02:23 PM
Quick Reply: Correct Torque Setting for Intake Manifold BOLTS ON 6.4L ?
