Fuel Pump shooting gas out of the side
Old 10-31-2011, 11:51 AM
Arbiter343GS's Avatar
I have a 1966 Plymouth Fury III, and When I went to start it today, the fuel pump began spewing gas out of the side of it. Do I need a new pump or is this another system making my pump do this?
Old 10-31-2011, 03:13 PM
Sounds like you need a new pump. I assume you checked the rubber fuel line & filter ??
Old 10-31-2011, 07:14 PM
Replace the pump, and CHANGE THE OIL. It's very common for this to happen, and for fuel to flood the oil pan. In my lifetime, I've seen one car that blew off one valve cover and the oil cap, and WITNESSED a Ferd starting up outside of a cafe, blew open the oil pan with a crankcase explosion.
Old 10-31-2011, 11:02 PM
Thank you, I will change the oil and pump, before the next time I run the engine. Thanks for the replies!
Old 11-04-2011, 06:45 PM
scotts74birds's Avatar
Wouldnt worry so much about a bang! But the gas can seriously wash-down the motor and add thousands of miles of wear to the rings and bearings. I had an issue once where the carb leaked, with no vent in the tank. It pushed nearly a gallon of fuel into the oil pan while sitting due to heat-expansion.
NeverEnoughAuto
09-12-2014 06:17 AM
Uberbricky
07-06-2014 08:10 AM
fmontez1
01-05-2012 04:33 PM
Foedoe
03-08-2011 07:47 AM
georgefla
11-11-2008 01:59 AM
Quick Reply: Fuel Pump shooting gas out of the side
