Trouble Shooting 318
Guest
Posts: n/a
Hello. I have a 1968 Plymouth Satellite with a 318. The motor starts after several cranks. It runs for a few minutes and stops. It will do this after each crank... the motor has a rebuilt carb and new fuel filter. a What should I look for to solve this problem?
a vacuum leak is a good place to start at. also, is the carb adjust properly? Was the fuel filter installed in the proper direction?
When I installed a fuel cell in my jeep i had the same problem, turned out to be the fuel filler was installed backwards.
Arbiter343GS
11-04-2011 06:45 PM
