Lower the compression on Big Block??
Old 01-17-2013, 08:33 AM
Air Bubba's Avatar
I want to lower the compression on my Big Block from 10.5 : 1, not looking to get to a specific number I just want to be able to run pump gas.
Here is what I have:
Engine: 446 Stroker - .030 bored 400 block – 440 Crank – Alum Childs & Albert Pistons running 10.5 Compression - 906 Heads
Heads have not been milled and block has not been decked.
In a related post I asked this question along with a Camshaft issue but want to start a new thread on this topic, I do appreciate all the good information on the last post.
I have been told I could run Head Shims and or Thicker Head gaskets.
How much will the .020 head shims lower the compression?
Then how much with the addition of the thicker gaskets? (.051-.059)
Also machining of the Pistons is an option, I have attached a picture of my Pistons.
I can face them down that is not a problem, plus it’s won’t cost anything.
Just don’t know how much to face off, any good rule of thumb?
Thanks
Old 02-06-2013, 04:20 AM
Garys69RR's Avatar
You are prob at more thah 10.5 to 1 C/R. Need the deck height, piston dome volume, head gsk thickness, head cc (prob about 88 cc on a 906 head) . I have a similar build and am at 12.5 to 1 C/R
Old 02-06-2013, 04:21 AM
Garys69RR's Avatar
Send this info, and then actual C/R can be determined.
Air Bubba
01-17-2013 09:54 AM
pipdog69
03-13-2012 11:01 PM
68satellite
05-23-2009 05:33 AM
Brent1960
05-17-2009 04:25 PM
mahd
04-02-2009 09:05 AM
Quick Reply: Lower the compression on Big Block??
