Magnum heads?
on
Magnum heads?
OK I have a 1996 Dodge Magnum 5.2L engine.
Will the heads from that engine fit an earlier model 318?
The engine I have needs the bottom end rebuilt. But I have a 1975 318 short block, that I would like to rebuild, so I can do a quick weekend swap.
I just need to know if I can use the same heads.
Thanks!
Thanks!
NO not practicable don't quote me on this some possible problems
Change the lifters ---AMC type ?
change pushrods -magnum style
Modify push rod holes
External oil lines
Magnum intake
Magnum head bolts
External oil lines
Magnum intake
Magnum head bolts
AMc lifters & hollow pushrods are needed as well as a different intake as the intake bolt holes are angled differently .
No external oiling needed , the rockers oil through the pushrods .
cudaracer
09-26-2011 02:43 AM
