need some help
Old 09-10-2011, 01:03 PM
mikerp76's Avatar
need some help
i have a 67 valiant witht the slant 6. i need some help deciding what to do about the exhaust pipe. at the moment it doesn't have a muffler and is dumped in front of the rear axle. i was wanting to run it out in front of the rear tire, but due to the parking brake cable running down the drivers side i was thinking of the passenger side. would this be acceptible or should i try to find the rear pipe that goes over the axle and run it out under the rear bumper?
Old 09-12-2011, 04:24 PM
DartcustomcrusieR's Avatar
i would run it out the back unless you have your heart set on side exhuast. I would also keep the 2 1/4 stock exhaust as well.
Old 09-12-2011, 09:26 PM
mikerp76's Avatar
i plan on keeping most of the stock exhaust. the issue i have now is that the exhaust pipe ends just under the back seat. and i can't find the rear half of the pipe that goes over the axle. i was thinking as a temp fix if it was possible to run it out the pass side without any major issues. i apperciate your reply on this as i can't seem to figure out how to do this.
Old 09-13-2011, 01:51 PM
no i seen a guy run a 2'' right across the trans and out the side. i would just make sure that you have the pipe a lil past the body to help with drone
Old 09-13-2011, 04:21 PM
mikerp76's Avatar
cool but i'm thinking of back by the rear wheel well opening. ill try to post up some pics of before and after.
Old 09-13-2011, 04:45 PM
i think i get what you are saying, kool cnt wait to see. im sayin you can easily put it anywhere out the side before the axle
Old 09-13-2011, 07:28 PM
mikerp76's Avatar
oh ok for some reason i was thingk you ment up by the front tire. it was a long day at work. but i think i have a plan and will post pics of how i did it as soon as i get it done.
Old 10-01-2011, 12:54 PM
do that exhuast yet?
bb427
06-04-2009 02:01 AM
my97dakota
10-17-2008 10:17 PM
my97dakota
10-09-2008 08:56 AM
FryGuy
05-24-2008 12:36 AM
greaterprophet
04-02-2008 08:26 PM
Quick Reply: need some help
