New cam shaft, lifters.
Old 01-19-2014, 07:56 PM
1968GTX's Avatar
Question New cam shaft, lifters.
I just took my valley pan off, and noticed that the cam shaft is rusted, pitted, and even has flatts on it in spots. Should I replace it with the same or should I upgrade it? And which brand should i use?
Old 01-19-2014, 08:48 PM
moe7404's Avatar
if you do a new cam. be sure it use zinc in the oil. check out zddplus.com i have used it for 5 years.
Old 01-19-2014, 09:02 PM
What does the nose of the cam look like? Do you want stock or performance cam... IF you really want to up grade get a roller cam and some 1.6 roller rockers
1968GTX (01-19-2014)
Old 01-19-2014, 10:56 PM
1968GTX's Avatar
That is what I was thinking about doing. Can you suggest a brand, I was thinking stock lift to not performance.
Old 01-20-2014, 03:51 AM
Mr.4spd's Avatar
I've had good luck with Comp Cams. Whichever brand you choose, I recommend calling them and telling them what you're up to and let them choose a cam for you, I know this requires turning in your 'Man Card' for a while, but you'll be glad you did. This pretty much guarantees the perfect cam for your combo.
1968GTX (01-20-2014)
Old 01-20-2014, 07:01 AM
1968GTX's Avatar
Can anyone tell me what cam came stock in my 1968 GTX, so I can get an idea on where to start looking?
Old 01-20-2014, 07:51 AM
pro-tech's Avatar
WHAT engine? I would use Mopar performance and go with a mild street cam/trailer towing cam..I think that how they list it...I have had the best luck staying with the factory stuff they know best what runs good...Just saying and Im not knocking any other cam manafacturers..The purple camshafts run and perform great...Bill
1968GTX (01-21-2014)
Old 01-20-2014, 07:53 AM
pro-tech's Avatar
What is the nose of a cam?????
Old 01-20-2014, 08:34 AM
Lunati or Hughes
Great cam, Great power!!!!
Old 01-20-2014, 09:18 AM
1968GTX's Avatar
440
Old 01-20-2014, 06:12 PM
demetri's Avatar
Originally Posted by 1968GTX
440
If this engine is original, it is the HP version. The cam of this engine was 268 total intake, 284 exhaust, .450 intake lift, .475 exhaust. You can go bigger, if willing to lose some low end torque, and given that this is not a heavy car (by Chrysler standards), you can certainly do so. You can look at my thread "440 build for Imperial" or something like that, where I discuss my cam option with .477" intake lift (cannot recall exhaust). Modern cams are a bit less conservative, in terms of having a bit more lift for a given duration. Modern oils allow that. In my case, I have a very heavy car w/ high gearing, and I cannot afford loosing too much low end torque. But I am willing to lose some, so that I can have good high speed performance. You can go a step or two beyond what I selected, but I would not go too far if I were you, as you may lose too much low torque, with little benefit (too much cam may require other mods to really give you benefits).
Old 01-20-2014, 07:39 PM
Mr.4spd's Avatar
I dropped a Purple Shaft .484 into a stock (stock besides headers and an aluminum intake)440 4 speed 4000# car and ran it on the street with no problems. That same setup ran 12.60 @108 at the track.
Old 01-21-2014, 09:33 AM
It’d be pretty neat to step up to something in the 256 range (like comp cams XE line). Great idle, great mpg, and a wonderful gain in torque down low where these mopars like to shine.
Old 01-22-2014, 02:26 PM
With stock exhaust manifolds something like this would be real good.
http://www.compcams.com/Company/CC/c...?csid=706&sb=2
Old 01-22-2014, 02:50 PM
I would go with the 284 cam 470 lift with 1.6 rockers. stock GTX cam is not a grocery getter it is a performance cam. sugested 256 Sounds like a down grade from stock
1968GTX (01-22-2014)
Old 01-22-2014, 02:53 PM
Nose ??? I always thought it was the part of the cam that was in contact with the lifter at max lift
Old 01-22-2014, 09:56 PM
1968GTX's Avatar
So that would be the smaller radius on the cam shaft right?
Old 01-23-2014, 06:42 AM
Nose is the high side of the cam lobe....
Heel is the low flat part of the cam lobe area....
Old 01-23-2014, 07:24 AM
pro-tech's Avatar
Well there you have it the official word from my buddy Bob Hogan...No relation to Hogans Heros..See still learning after all these years...I have never heard that term before...It must be a west coast thing..(Like the west coast girls are hip I really dig those styles they wear.)Now they pierce everything and distroy there bodies with grommets..Lol...Bill
Old 01-23-2014, 10:40 AM
.....Old Rod & Custom Magazine use to use that terminology... LOL
But Bill you might be rite..... It's a Racing / Hot Rodders slang term...
Sorry for the highjack 1968GTX.... Now back to the topic !!
Old 01-23-2014, 10:50 AM
I'm Guessing there has been nothing done to the motor?
Just a stock bottom end and heads?
Are you going to upgrade the rockers or are you looking at just wanting to stay with a hyd. cam replacement?
This would be a great replacement... I think you might look at it....
http://www.lunatipower.com/Product.aspx?id=2334&gid=362
One of the jobs I did has this cam and the guy loves it.... Drive the crap out of it.... Weekend cruiser with good low end power and good vacuum for his power brakes.
NOTE: This is for the 3 bolt cam sprocket !!!
1968GTX (01-24-2014)
Old 01-24-2014, 12:59 AM
1968GTX's Avatar
I am going to try and pull the heads and the rest of the cam out this weekend provided I can get the garage warmed up enough to work out there. Supposed to be only 10 deg. On Saturday. Thank you all for the help, you all are a great bunch of help.
Old 01-31-2014, 09:56 PM
1968GTX's Avatar
Is it possible to work on that cam shaft replacement while the engine is still in the car, or do i need to pull it out?
Old 01-31-2014, 10:20 PM
  #24
Just the radiator & distributor of course !!
Old 02-04-2014, 04:30 AM
  #25
1968GTX's Avatar
Am I going to have to replace the cam bearings too, or should I tear it apart and wait and see, and if so can I achieve this with engine in car?
Old 02-04-2014, 07:49 AM
  #26
I think at this point, you should consider a freshen up of the engine.. Why take a change on the rest of it.
Old 02-10-2014, 07:56 PM
  #27
1968GTX's Avatar
Well I got the cam shaft out this weekend, I was hoping for some numbers to be on it so I could cross reference it with An after market one. No such luck, the only numbers on it are forging number, no part numbers. I am going to post some pictures of it this week.
Old 02-11-2014, 03:24 PM
  #28
1968GTX's Avatar
I got some pics posted of my cam shaft.
Old 02-12-2014, 01:47 PM
  #29
1968GTX's Avatar
Is there a formula to checking to see what camshaft i have?
Old 02-12-2014, 02:29 PM
  #30
http://www.lunatipower.com/Tech/Cams/CamSpecTerms.aspx
Quick Reply: New cam shaft, lifters.
