No fire after rebuild
Old 06-18-2018, 12:50 PM
mab4962's Avatar
I have a 1973 Plymouth Satellite Sebring which I just put a new engine in - 318 V8. The car was running before I started the swap. New engine (professional rebuild), new wires, plugs, battery, distributor, rotor and cap. The car tuns over but no fire. Any suggestions would be appreciated. Thanks in advance.
Old 06-18-2018, 01:25 PM
Do you have fuel, in the tank and in the carb?
Do you have spark, 12 volts at the coil?
Air, fuel and spark, you need all three.
Old 06-18-2018, 02:26 PM
mab4962's Avatar
I do have gas in the tank. I am using starting fluid until the fuel pump gets gas up the line to the carb. I have no spark from the coil that I can detect (I literally held the wire in my hand as I turned the engine over). How do I check to see if there is 12V going into the coil?
Moparnut1970
09-01-2019 03:38 PM
retrocar66
12-21-2014 03:31 PM
68383camperspecial
11-04-2012 09:18 AM
69dartgirl
05-06-2012 08:28 PM
silvermopar
10-19-2009 07:43 AM
Quick Reply: No fire after rebuild
