Problem with cold start Floods out, won't start
Old 01-22-2013, 12:39 PM
jbda's Avatar
97 Chrysler Cirrus 2.5L V6 LX, 130,000 miles. Transmission replaced 2 yrs ago. One Owner.
Problem with cold start, barely starts and sputters, but will not stay started. Floods out and gases out the plugs. Can anyone give helpful advice, or faced same issue and what might be the problem? Was running fine 2 months ago, but then suddenly wouldn’t start one morning. First issue: Not firing. Neighbor mechanic replaced distributor, cap, rotor, and spark plugs. Then car started flooding and still wouldn’t start. So then replaced crank sensor, map sensor, and temp sensor. Fuel pressure then read 49 psi (normal). Code also determined O2 sensor, so replaced that as well. Ran fine for a couple of days, then started flooding and gassing out plugs again. Carried car down to local Dodge dealer for diagnostic. No codes were thrown, checked timing and all OK. Replaced spark plugs again to Champion as recommended by dealer instead of Autolite. Still didn’t fix problem. Can anyone HELP!
Old 01-22-2013, 01:37 PM
PK1
PK1's Avatar
Man this is a good one.. Im gonna throw out ideas as I cant see your car.
O2s will code out when soaked in fuel. The primary "upstream" gives feedback to the ECM. The down stream simple sends signal for emissions. So save the old o2.
Are you burning the primary o2 wires? Did you cut or splice this assembly? Are you burning sensor wires in general? The run after the sensor swap is a clue but something then failed so ground or wire strain or burn?
Did the dealer give you a print out of the data? I HATE to not give you an idea of where to go but honestly you need someone with the ability to read ecm data. For 75 bucks the dear should have given you that. A snap on or equivalent tool that can give you "run" voltage and "engine on" voltage. The system needs a way to tell the parts what ambient air and temp is. If these voltages are out of parameter they wont work. She may "limp" for you but not run right.
Excessive fuel in a system that works well leads me to temp sensor ( which you changed) and then TPS ( where the throttle blades are opened too ). I would check voltage there and see where you are. Clogged converters do this too.
Have you been running withcheck engine light for a while? Say 30 plus days and this happened?
The OBD2 in your car will run two system checks. An instant MIL or one that codes after 100 miles or 2 hours.. Or a combination of the two. These lights are for the consumer. You can read much more in the ecm. If you go back to the dealer ask for the senior tech. Ask him to read all the cached data and check all your sensor readings.
Old 01-23-2013, 06:49 PM
mstrtrv's Avatar
The check engine light never came on.
Old 01-26-2013, 11:57 AM
jbda's Avatar
check engine light
there is no check engine light, the only code that ever came back was checked at advanced and that showed the o2 sensor. That has been replaced. It didn't throw anycodes at the dealership and they said they didn't have a print out. They were very unhelpful and wanted to charge over $600.00 for checking it out even though the agreed price was $89 for a diagnostic check. they pulled the timing cover off and the manifold and said the spark plugs were bad ( just replaced) and the timing was off. Told them we were only paying the 89 and we towed the car home. Replaced the spark plugs again this time with champion plugs. The ones I just replaced were already gassed out. Checked the timing and as we thought it was in time. Any Thoughts?
Old 01-26-2013, 12:04 PM
jbda's Avatar
Thanks PK1 for your input, I'm forwarding on to the Neighbor mechanic who is helping with this.
Old 01-26-2013, 02:07 PM
Mr.4spd's Avatar
If it started all of a sudden it would be helpful if you can remember any recent work leading up to the issue. Pull a plug and ground it against the block (still hooked to the plug wire of course). Have a buddy turn it over. Got spark? Let us know. By the way, diagnostic work is the best and cheapest way to find and repair the problem, throwing parts at it is the most expensive.
Old 04-01-2013, 08:33 AM
jbda's Avatar
He has been chasing wires and it has good spark, good volts at the distributor. Changed the TPS, and MAP sensor, new spark plugs nothing changed. Put a code reader on it again and it is showing no codes. Figured computer could be bad if not showing any codes? Changed computer, no difference. It is still gassing out the plugs and is hardly running and is non-drivable still. Throwing parts is proving to be the most expensive! Totally lost and in deep! Any suggestions? Thanks for the past replies, we appreciate the input!
Old 04-01-2013, 09:56 AM
jacilynn_s's Avatar
I have a funny idea that the air intake is getting plugged intermittently. Not likely but easy enought to check. You would be surprised at how quickly a mouse can make a nest in the oddest places.
Other thing is a cold wire syndrome. That means that cold the wire withdraws far enough to cause problems but works fine when warm. Look for places around the battery that are bulged out. If you slice them open and its all white powder on the wiring harness you found it. If your battery is not under the hood it can still happen in places under the hood anyways.
Old 04-01-2013, 10:22 AM
Cam position sensor ? jumped timing chain ?
josehf34
12-15-2013 04:52 PM
deathwish
11-18-2013 10:38 AM
mblackmon
05-17-2012 12:12 PM
fastdakota84
06-25-2010 01:06 PM
raceware
05-16-2008 04:50 AM
Quick Reply: Problem with cold start Floods out, won't start
