What do i need for this?!!!! Need 2 Know ASAP
Old 08-11-2011, 01:50 PM
gearheadmike's Avatar
Ok 85 diplomat 318 auto with electronic fuel computer crap. Im changing it to the old 70's set up well ignition. as it runs like crap and no power. (only 83k on it)
I know i need a none electric 2bbl carb/a 2 prong vac distributor/the ecu/resistor/and?
what type cars should i look to pull this out of? And what ecu do i need the 4 or 5 prong? and do i need a different coil or can i use mine?
Im going to a junk yard tomarrow and need to know asap and i know they sell a kit but i dont have the funds for that. Let me know thanks And does anyone know how to wire this? or has a pic or something?
Old 08-11-2011, 02:07 PM
So you need an Ign module, distributor, balast resistor Carb and maybe a manifold if you want to use a 4bbl carb any 318/360 can be a donor Doesn't matter if it is a car or Van except for the linkage
Old 08-12-2011, 05:20 AM
so a 340 or 360 intake will work? and where is the cheapest kit online? i might just go that route
Old 08-12-2011, 11:18 PM
Check the junk yards first !! Dist, ign,balast resistor can be had cheap..2bbl carb and intake cheap too !!! Unless you want an aluminum manifold.. Look early to mid 70's LA motor
Old 08-13-2011, 07:20 AM
There are articles you can find on the www:
http://www.oldengine.org/unfaq/leadfoot/leanburn.htm
This one "leans" toward /6 engines, just ignore the specifics of a /6 carburetor replacement:
(It's a pdf)
http://www.turbo-mopar.com/forums/at...1&d=1269830340
Old 08-15-2011, 04:22 PM
ok i got a icu from a 360 dodge truck with the resistor but the dissy was a duel pick up type. so i got another icu and single distributor from a old dodge rv with a 360 will these icu's work they both have the chrysler mark. and i scored a eldebrock performer 4bbl intake for $25 also i have a accel super coil can i use that in swap or will i need anything else?
70RT383
09-02-2011 07:00 AM
PLYMOUTH BOB
01-13-2011 11:22 AM
hellzombiex
04-20-2009 11:58 AM
Crazy4Carz.Com
04-09-2009 06:44 AM
blue 68 gts
04-09-2009 02:06 AM
Quick Reply: What do i need for this?!!!! Need 2 Know ASAP
