Why is my timing so high
Old 10-16-2017, 06:55 PM
cmrris's Avatar
I have a 360, bored .060 over, eagle rods Keith Black pistons magnum heads, new everything. I had a Mopar purple cam in it originally, and the timing ran way advance- around 30 initial and 50 or so total. I tried everything, re curved the distributor and all, still wanted all the timing. That camshaft wiped out after around 800 miles and I too it all apart to clean and put it back together this time with a comp cams XE268. It STILL wants all that timing. I'll probably just ignore it and give it what it wants, but why would it be doing this? Comp timing set installed at the o mark, crank keyway on the domed slot. Could the timing set cause it to want the timing? The damper is a Summit one, very good quality, and it lined up with 0 at TDC, I made sure to double check the second time putting it together so I don't think that's a problem at all.
Old 10-16-2017, 07:00 PM
What the Part number on the timing set you used, so I can look at it?...
Old 10-16-2017, 08:01 PM
cmrris's Avatar
balancer- https://www.summitracing.com/parts/sum-163318
timing set- https://www.summitracing.com/parts/cca-2103
cam- https://www.summitracing.com/parts/cca-cl20-223-3
Old 10-17-2017, 03:53 PM
ARE you checking it at full advance with vacuum or just the dist advance 50 degrees with the vacuum advance is in the ball park !!!
Old 10-17-2017, 04:11 PM
cmrris's Avatar
Vacuum advance capped off, initial timing at 800-1000 rpm and total at 2000-2500 rpm. It has one light spring and one medium spring on the weights.
Old 10-19-2017, 09:08 AM
I would re check the timing marks against TDC If you are having to setting it at 30 initial something is wrong.. I had a 360 with a 284/ 484 purple cam 12-14 initial was fine.
Old 10-19-2017, 09:17 AM
cmrris's Avatar
I'll work on it here soon but it absolutely won't idle below 28 degrees.
Old 10-19-2017, 09:18 AM
cmrris's Avatar
Only thing I can think of is the advance/retard on the timing gear itself. How does the work? Would that make sense at all?
Old 10-19-2017, 09:34 AM
I Would install it O-Cam and O-Crank... I'm Guessing you used the ^-Diamond and have the cam advanced and the engine is not liking it...
I have seen some of these stamped wrong or what you might call defective casted.... Just my 2 cents...
But I would install it as stated above....
Keep up posted....
Old 10-19-2017, 09:48 AM
cmrris's Avatar
Keep up posted....
I'm 98% sure I installed it on the o slot. The one to the right of it with the domed groove
You can barely see the stampings on this picture but it's the best I could find
Old 10-19-2017, 04:12 PM
I think I would match it up with the old one or pick up a Cloyes set and see if that might fix the issue.
That cam is a "hush puppy" you should not be having this kind of an issue
Unless we have a problem somewhere else in the motor? Like an intake vacuum leak of something.
Old 10-19-2017, 07:28 PM
Archer's Avatar
c -
I'm thinking along the same lines as Bob, but don't forget the stupid stuff.
Is your timing marker in the right place and if you have an adjustable timing light, is it zeroed correctly?
You timing may be fine, but your readings off.
It's happened.
Old 10-19-2017, 07:45 PM
I'm thinking dampner has spun so timming marks are off. You need to veryfiey top dead center ..............
Old 10-19-2017, 07:54 PM
cmrris's Avatar
It's a new dampner and it's done it since I put it on, and it does show 0 at TDC. And get another timing light and check that
Old 10-20-2017, 08:01 AM
cmrris's Avatar
I put my timing light on my Toyota this morning and it's working correctly on that, so a bad timing light isn't the problem
Old 10-20-2017, 11:31 AM
cmrris's Avatar
I tried checking the dampner with a homemade piston stop and it seems to be fine. However, I began messing with the idle mixture screws and it seemed to run better at lower timing. Soooo, could my carb be a factor in any way?
It's a Holley 600cfm I bought off Craigslist. Vacuum secondaries
Old 10-20-2017, 12:05 PM
First off most used Holley's are junk !! So it could be carb problem?
Old 10-20-2017, 12:21 PM
cmrris's Avatar
I had it on another motor before and never had a problem. Guy sold it cheap because he could never get it to work right. He put on a wrong gasket and gas would dump in the motor through the power valve chamber. Even had the right gasket in the rebuild kit gave gave me with the carb.
Old 10-20-2017, 02:53 PM
LOL... So much for new everything !!!!!!!
Old 11-03-2017, 07:07 AM
cmrris's Avatar
UPDATE: I messed with the carb enough to where it idled when the timing was turn back to where it should be. Guess the carb ended up being the problem after all. Thanks for all the help!
JS23
12-18-2014 07:12 AM
Gorts 5th
12-19-2012 04:52 PM
a.johansson84
05-27-2012 03:30 AM
ShowYourAuto.com
03-18-2011 11:24 AM
recondotexas
02-06-2010 10:39 AM
Quick Reply: Why is my timing so high
