1976 D100 question.
1976 D100 question.
I have an automatic trans in my truck which needs a steering column. I have another 76 but it is three speed on the column. Will that column work at all on the automatic?
Just what are you asking?
If you need an auto that's what you need.
I'm not sure I understand what you are looking for.
my blue 76 is a three speed automatic. The column in my blue truck needs replaced. My black 76 is 3 on tree. I'm not saying I can just put the one from the black truck into the blue truck and it's done. The shifting mechanism is different on the trucks. Is there a way to swap out the mechanism so it can work for the blue automatic truck
So you want to use a column shift use what you you need.
