64 Fury axle sha6
Old 03-15-2022, 09:21 AM
Pacecar78vette's Avatar
64 Fury axle shaft
I am new to the forum, I did a search but could have missed a previous post if this has already been discussed I apologize. I was working on the rear brakes on my newly acquired 64 fury, using a puller to remove the outer flange and drum. Unfortunately it split the outer end of the axle shaft. I have not had any luck finding a replacement.
Does anyone know where to get a replacement shaft or a shaft that will convert it from the 2 piece to a 1 piece design? Any help would be greatly appreciated.
Thanks,
Nathan
Old 03-15-2022, 09:30 AM
I think Summit has one piece shafts but I think you need to cut it to length.
Mark Williams
Quick Performance
strange
All have what you need but if you can find a mone piece shaft for a later later that will work.
I've been assuming you have a 83/4 axel something you need to know.
I would also try usedpart.com...
Old 03-15-2022, 09:59 AM
Mark Williams
Quick Performance
strange
I did check on Summit, however I will probably have to call as their website said they did not have a direct replacement listing for it. Do you know if any of the later axle shafts are a direct replacement but updated design for these? Did chrysler keep the same housing/rearend and just change the design of the shafts?
Old 03-15-2022, 10:42 AM
Desert Valley Auto Parts in Arizona..... Maybe up to 1965.... Is that the Axle with the adjustable bearing flange to the outside of the bearing ?????
Old 03-15-2022, 10:54 AM
This axle has a tapered roller bearing that holds the axle into the axle tube via the backing plate for the drums, I believe. The outside flange that the wheels/drum hold onto is removable and is held onto the tapered axle shaft with a keyway and large center nut.
I believe 64 was the last year for this design. I was wondering if anyone knew if any later years are a direct replacement axle shaft for this style
Old 03-15-2022, 12:59 PM
I forgot about the bearings, try parts for a 65 Fury, the last time I needed an axel I went out to my local yard and picked one up.I was looking to replace two big bolt pattern axels from a big Chrysler with the 5 on 4.5 bolt pattern. They had racks of mopar axels so whith a tape measure I picked out what I needed...
I would think there would be a salvage yard you can call locally.
Old 03-15-2022, 02:07 PM
Thanks, I appreciate all the help. I have not been able to figure out what newer years fit and we do not have any salvage yards in my area to match up axles. I may have found a conversion kit through a local drive line company that should come with all new 1 piece shafts, bearings and retainers. I will update if anyone is interested in the future.
Cuda Man
08-22-2021 05:46 AM
randy4662
08-27-2015 05:29 AM
nashvegas99
05-15-2014 01:49 PM
Richard Champion
05-12-2012 10:22 AM
07-24-2009 09:20 AM
Quick Reply: 64 Fury axle sha6
