Help and advice on a 727 transmission
I have a 1974 motorhome international chassis 345 eng 727 trans it is cable shifted when shifting from park down to low its ok but coming back to park the cable buckles put in new cable it does same thing any body got an idea mhutch1948
Try Ordering and using the Morse Style cable. Much more Heavy Duty of a cable. You can get them from "PTO Sales" OR even Hindle Controls...
Just my 2 cents
Just my 2 cents
morse was used on all the internationals I worked on cable I ordered was exactly like the old one it worked when we bought it but it has set 3 yrs my wife has passed and 110 v troubles this spring got into it I live in texas have been without a computer for 2 1/2 years haven't found a dealer for morse to me it feels like gear selector even without cable is to tight cable we got cost $200.00 will check on these other much thanks mhutch1948
Does it work on when its unhooked from the trans? I mean Will it move freely? If not lube the cable. Maybe we are missing something. I know... I had to lube the one on my 1968 Dodge D200 and also my 1977 31' Explorer motorhome with a 440/ 727 trans. I used Zep45 to free both of them up..
Keep us posted...
Keep us posted...
hey racerhog cable unhooked from trans and dash shifter two fingers moves fully . I took a small pair of vice grips on and tried to shift trans went down fine' but back up cable started to buckle. is it possible that because it has set so long that with out trans not pumping fluid that everything is not being lubed I changed filter 3 years ago but never ran engine after. other thing got in the way. thanks for your help its sure got me stumped mike-mhutch1948
I have 3 more projects to do then I can start on MY retirement project my 55 dodge coronet 2d have a lot of ideas for it and a Chrysler for eng, trans, rearend and drive shaft mike
Kind of sounds to me like it is just dry and needs lubrication in the trans area in that case.. You might want to just pull the pan, and see whats up, or just light it off and see if by running the unit it will free itself up after the fluid gets thrown around and about?
Boy. Thats a lot of projects to have going on!!!!! But sounds like fun...
changing out my 4 speed for a 727 torque flight
Have a 68 RR. A few years ago converted from 727 torque flight to a 4spd. Now I have left hip problems and have trouble shifting. Will I regret going back to the 727? to me a hot rod was always a 4 speed. Thanks
Have you driven a car with a hydraulic clutch? Peddle presser is minimal and smooth. There is probably a kit for your RR out there.
norcalitwin26
06-05-2014 02:16 PM
hckrphil
05-16-2014 05:23 PM
2002ram440
04-21-2010 11:20 AM
