Humming at highway speeds
I been trying to track this humming sound down, I notice it when cruising at highway speed. The humming goes away when I take my foot off the gas. My next approach is replacing the center carrier support and U joints the truck is a 72 d100 318 with a 3 speed trains. All my fluids are topped off and fresh. Anyone might know what it could be?
I think you're on the right track....
My72D100 (09-29-2019)
See if the pinion nut is tight......
You will need to drop the drive shaft and if it is lose pull it off and clean up all threads on the pinion and nut with break kleen then put it back together with red lock tight........ You should actually replace the nut but try this first.
