1953 Dodge Meadowbrook
So I am seeking any and all help so I had someone start doing my brakes and ended up not doing them so I'm stuck with trying g to put them back myself so I do know somewhat about the cam pins and the anchor bolts with the arrows so if anyone can send me any and all information videos links on how to put them back and adjust them correctly from scratch
please I would greatly appreciate it thank you
OK so when I was going to try everything to put everything back on and do the adjustments like you all said and going by all the links you all shared I noticed the spindle looks VERY VERY worn down like it was rubbing against something any suggestions before I try and put it back together please
I found a MTSC (Master Tech Service Conference) brake video from 1950. However, it appears to depict the same duplex drum brakes like on your 53.
Also, is the other side of the car still together? If so, you can use it as a reference.
Chrysler Master Tech - 1950, Volume 3-6 Brake Shoe Adjustment and Alignment
Ok so what im trying to ask is this please on the cam pins and spring (the little plate underneath it )is there a certian way they are to be bent to hold the shoes also I think I read somewhere that those plates have to be facing with the lobes facing outward would that be true please like the picture I just added with the circles and arrows pointing
Crisjr14
12-12-2020 12:36 AM
