1975 Dodge Dart Torsion Bars
I am planning on swapping my /6 225 for a 318. I located some .087 torsion bars from a 1970 Duster and am curious as if they would fit my Dart?
I have posted about this earlier but could not locate the post for some reason...
Your help is appreciated
Thanks for the reply I know they are both A's but I am wondering if the 1970 bars will fit my 1975. I have only replaced stock, same year replacement torsion bars.
here is a point for reffrance. i have 1967 dart factory service manual. dont know how close it is to your car. torsion bar info. dart. length 35.8" std suspension 6 cyl bar dia 0.83. std susp 8 cyl bar dia 0.85. heavy duty susp bar dia. 0.87 coronet length 41" std susp 6 cyl 0,86 8 cyl 0.88 heavy duty susp 0.90 police, 426 & 440 engine 0,92 station wagon 0,88. ian not sure the station wagon number is right.
Thanks guys
Outstanding info Moe and 440. I was assuming the 1970 torsion bars would fit but with the info you gave me makes me feel better about buying them. The guy only wants $45 for them...
Thanks again
Thanks again
removing and installing them is not easy. you need to get better info from the experts. but ill add , be for you back the adjusting screw be sure the threads are clean. if they are not it can strip the threads when you back them out. i found out the hard way. but DO talk to some one that knows how to do. BEFORE you do it.
