Brake drum???
Hi, is the brake drum fixed in the hub nut? or should it just be to use a puller and pull him? I removed the hub nut and used a puller between the tire bolts, but my extractor broke (cheap crap). It's on my Dodge Pioneer from 1961..
It's not clear to me whether you are trying to get the hub/ drum assy off the axle or trying to now get the drum and hub separated
You need a massive puller for this, and good ones are not cheap. You COULD make one with heavy enough material. The good ones used to be made by people like OTC http://shop.advanceautoparts.com/wcs...4_pri_larg.jpg Those will pull just about any tapered axle hub on the planet, Jeeps, Internationals, Dodges. They make not work on early Fords or VW's with the "big" bolt pattern around the edge of the drum. They are big, expensive, massive, strong. The nut and "wrench" is built this way so you can tighten it up, and tap against the nut and the wrench with a hammer, to "shock" the hub loose. Whatever you do, don't use a puller that hooks around the outside of the drum, nor pry around the outside. Sometimes putting pressure on the puller, then heating the center of the hub helps. To separate the hub and drum.................. Generally, the wheels studs have a "riveted" area where they come out the front of the drum and transition to the stud itself. This is generally called a "swedge" or a "swadge." You cannot just drive the studs out, you'll ruin the holes in the hub. You need a "stud cutter" or a "swadge cutter" Here's some examples http://www.goodson.com/Brake-Drum-Swedge-Cutting-Tool/ |
Originally Posted by 440roadrunner
(Post 88852)
You need a massive puller for this, and good ones are not cheap. You COULD make one with heavy enough material. The good ones used to be made by people like OTC http://shop.advanceautoparts.com/wcs...4_pri_larg.jpg Those will pull just about any tapered axle hub on the planet, Jeeps, Internationals, Dodges. They make not work on early Fords or VW's with the "big" bolt pattern around the edge of the drum. They are big, expensive, massive, strong. The nut and "wrench" is built this way so you can tighten it up, and tap against the nut and the wrench with a hammer, to "shock" the hub loose. Whatever you do, don't use a puller that hooks around the outside of the drum, nor pry around the outside. Sometimes putting pressure on the puller, then heating the center of the hub helps. To separate the hub and drum.................. Generally, the wheels studs have a "riveted" area where they come out the front of the drum and transition to the stud itself. This is generally called a "swedge" or a "swadge." You cannot just drive the studs out, you'll ruin the holes in the hub. You need a "stud cutter" or a "swadge cutter" Here's some examples http://www.goodson.com/Brake-Drum-Swedge-Cutting-Tool/ I try to remove the drum so I can check the brake pads look and brake cylinders. The decreased unevenly behind, so it did not go through the Swedish vehicle inspection. |
I'm thinking about this kind of puller. It says "fits most drum brakes."
http://biltema.se/ProductImages/19/large/19-1139_l.jpg |
I cannot tell how that thing works, can you post a link where you found it?
(Post 88947)
I found it on a swedish site http://biltema.se/sv/Bil---MC/Verkty...ragare-191139/ |
Sorry, I just don't know. It appears to be threaded, but the cylinder in the center must be large enough to go over the top of the center of the hub.
What you need for the rears on the older Mopars Is a slide hammer. Has 3 fingers that bolt to the axel studs with a 18"-24" bar with a big weight to slide on it
Originally Posted by TVLynn
(Post 88975)
(Post 88976)
I disagree. What he has is the old tapered axle with the huge nut on the end. You need a tool (or make one!!) like the OTC one I referenced.
If you just want to pull the drum for brake job, Then I just took off the nut and bearing and take the drum off that way.
Originally Posted by Timmoparman
(Post 89196)
so easy was mine forward. But back it's not losing by simply removing the nut. I was try that already... |
I havent worked on the taper axle/drum assy in a long time but i have had luck heating the drum close to the axle and giving it a decent 'bump' with a hammer.
Originally Posted by MrOldart2U
(Post 89938)
Ah, very good. I'm happy you got it off. Here in the states, there are a few older "rigs" which used those, old Fords, Studebakers, and of course Mopars. Jeeps, International Scouts and pickups. Some of those were a bastard to remove after years of rust
(Post 89993)
So, now I sat there glued new brake shoes and lubricate the brake cylinder on the right side. Now it should go through the Swedish vehicle inspection. I'm going in on Wednesday at 15:50 Swedish time .. just keep your fingers crossed |
