new Challenger wheel alignment
Old 04-07-2016, 10:56 AM
Archer's Avatar
Guys -
So I bring in my 2011 Chally for a wheel alignment, because the camber was noticeably off on the passenger front. Apparently, you need to install an aftermarket kit to adjust the camber.
1. What the hell was Dodge/Chrysler thinking?
2. Anybody do this, seems to be a lot of work, for some thing that should be factory with the car.
3. Any info appreciated.
Old 04-07-2016, 01:13 PM
Mmmmmmmmm Kind of......
Slight adjustments are performed by adjust the Engine Cradle... Larger adjustments will have to be done with installation of an adjustment bolt package.... It should all be cross checked with a 4 wheel alignment machine. And also hope the EHPS (Electro Hydraulic Power Steering) didn't get damaged. "If so Equipped"...
And The there is a Non-SRT8 and a SRT8 setting....
Keep us posted...
http://www.spcalignment.com/index.ph...c&task=details
Archer (04-07-2016)
Old 04-07-2016, 01:56 PM
Archer's Avatar
Bob -
Thanks.
Gets worse. Only ONE wheel is out of camber (negative), so by moving the engine cradle, it will probably mess up the other side.
Back to #1. What the hell was Dodge/Chrysler thinking?
Old 04-07-2016, 01:58 PM
Originally Posted by Archer
Bob -
Thanks.
Fiat....lol
Old 04-08-2016, 05:49 PM
Have you checked the suspension/ ball joints
Old 04-09-2016, 08:11 AM
DDodger's Avatar
What is a Chally?
Old 04-09-2016, 05:03 PM
Archer's Avatar
TV -
Suspension and ball joints are solid. Car tracks and handles correctly.
Have to figure out where/why the camber is off.
Old 04-09-2016, 07:13 PM
How far out did the alignment printout say it was?
Old 04-10-2016, 11:57 AM
Archer's Avatar
Bob -
I don't have the print out (Mavis), but if you look closely, the passenger side is slightly more negative than the driver's side. A casual glance, and they look fine.
I changed the front tires today, and the passenger's front wheel was slightly out of true. It kinda indicates the wheel may have been hit or got pot-holed before I bought it. (OK, where I live, the pot hole thing could have been me...) Going to have my regular guy take a look at the suspension and see if there's anything I missed.
This is my daily driver and it's always really felt solid, doing about 80 highway miles/day.
Old 04-10-2016, 12:48 PM
Drag Pak's Avatar
have a look at the lower control arm inner bushing and anchor bolt. It is a traveling bushing and if it has been hit, it may be seized on the bolt or smashed.
Old 04-11-2016, 06:24 AM
Archer's Avatar
DP -
Will do. Thanks!
Old 04-13-2016, 06:21 AM
Archer's Avatar
Guys -
Quick up date. Went over the suspension and everything was intact. Since the car doesn't pull and there's no abnormal tire wear, just going to leave it alone. It hasn't caused any problems in 20K miles, so probably won't.
Thanks for the help!
Old 04-13-2016, 01:28 PM
Just an FYI.....
Camber - Left -1.05*
Camber - Right - -1.35*
STD Specs...
So I agree.... Could look like a lot....
Old 04-13-2016, 03:08 PM
Archer's Avatar
Bob -
Well, I guess Chrysler knows what they're doing ...
So we're talking ab out a 0.3* difference??? That shouldn't be noticeable.
I have to see if there was a spec sheet generated with the alignment.
Thanks again buddy.
10-04-2012 11:09 PM
DusterDude88
04-30-2012 08:05 PM
mfleck_us
09-11-2010 06:27 PM
sgp7679
06-14-2009 04:19 PM
johnny4915
11-29-2008 05:05 AM
Quick Reply: new Challenger wheel alignment
