Brake lights don't work!
Alright here's my dilemma..my brake lights won't work..my regular lights and turn signals work, and I replaced the brake light switch and have power to both of the prongs on it...I'm guessing that the wire is bad somewhere to back..but I'm never sure..any help is appreciated!
I would check the steering column harness. The bottom of the column has a large connector that the brake lights run through. It may be loose or melted. If nothing else it's a good place to start your investigation with your meter. Check out your FSM for other body harness connectors, I think there's one more between the column and the bulbs. Good luck, and happy hunting.
I had the left brake light not working and both turn signals working. Turned out to be the turn signal switch. Check the harness and connections but if you don't find anything take a close look at the switch.
Thanks fellas ill do that tomorrow..im tired of working in the dark....
Also the wire goes to the drivers side kickpanel where it connects to the body wiring going to the back. Another place to check for voltage.
Alright so I have voltage at the steering column harness..but none at the kick panel harness.....I have no clue where to go from here..any help is greatly appreciated!
Would it be possible to run a wire from the steering column harness into the kick panel harness and bypass the stock wire?
Originally Posted by 70fury383
(Post 86334)
I'm not a fan of overlays unless absolutely necessary. Always try and find the area the wire is messed up and correct it accordingly. Also, have you checked the bulbs? If it's a dual filament bulb, that could be your issue. The chances of both blowing at the same time, not likely. But you never stated you checked them, and you never stated if they both went out at the same time. |
(Post 86334)
Here's how all turn signals work on these cars, exempting imports and some new US vehicles with SEPARATE stop and turn lamps Power goes to the brake light switch from a "hot" fuse, IE key does not have to be in either run or accessory When the brake switch is activated, it sends power up to the column, the turn signal switch The turn signal switch ROUTES the brake switch power If signals are OFF, (centered) BOTH rear turn lamps receive brake lamp power If signal is to one side, whichever turn signal lamp is selected is PREVENTED getting brake switch power so that the turn signal can flash If you are getting power from the brake switch up to the column AND both turn signals work properly (flash) THE TURN SIGNAL SWITCH is bad "Back in the day" (when I was young and stupid) and long before Al Gore invented the www, or we "kids" figggguuured these cars would be worth somethin', I devised a "workaround" for some switches I discovered that on the newer cars, which have the 4X switch incorporated into the column switch, that I could break off the 4x button (to prevent it from being activated) and move one wire, or jumper one wire, (My senile mind forgets) and "fix" the turn signal switch. So you ended up with no working 4x flashers, but at least the signals and brake lights work. DO NOT ask me how I did this. This was FORTY years ago!!! |
Blue - all rear lights work, turn signals and flashers work too so it can't be the bulb
440 - im gonna take a wild guess and say the turn signal switch is in the steering column?..how difficult is that to replace? |
Originally Posted by 440roadrunner
(Post 86336)
!! NO !!
Here's how all turn signals work on these cars, exempting imports and some new US vehicles with SEPARATE stop and turn lamps Power goes to the brake light switch from a "hot" fuse, IE key does not have to be in either run or accessory When the brake switch is activated, it sends power up to the column, the turn signal switch The turn signal switch ROUTES the brake switch power If signals are OFF, (centered) BOTH rear turn lamps receive brake lamp power If signal is to one side, whichever turn signal lamp is selected is PREVENTED getting brake switch power so that the turn signal can flash If you are getting power from the brake switch up to the column AND both turn signals work properly (flash) THE TURN SIGNAL SWITCH is bad "Back in the day" (when I was young and stupid) and long before Al Gore invented the www, or we "kids" figggguuured these cars would be worth somethin', I devised a "workaround" for some switches I discovered that on the newer cars, which have the 4X switch incorporated into the column switch, that I could break off the 4x button (to prevent it from being activated) and move one wire, or jumper one wire, (My senile mind forgets) and "fix" the turn signal switch. So you ended up with no working 4x flashers, but at least the signals and brake lights work. DO NOT ask me how I did this. This was FORTY years ago!!! I love this guy. Awesome knowledge. |
Originally Posted by blue 68 gts
(Post 86347)
(Post 86339)
(Post 86336)
(Post 86339)
440 - im gonna take a wild guess and say the turn signal switch is in the steering column?..how difficult is that to replace? Generally you need a wheel puller and if you have a front balancer puller, you can use that: http://media.toolking.com/catalog/pr...cer_Puller.jpg The turn signal switch is right there "on top" but the caveat is that some trim parts won't allow the harness connector to come out without tearing things apart, depending on the car model. FRANKLY I would not be the least bit adverse to cutting the wiring off the old switch close to the switch, so you now have a connector with a long pigtail. Then cut the connector off the new switch about an inch from the connector, so you can see the wire colors if necessary. If you do a good job of connecting with "butt connectors" nobody will ever care. Be gentle, NO prying!! IF you get all the proper screws, etc, out, it will come right out. |
I can't thank you enough 440...my dad has a wheel puller and is gonna help me when the new part gets here...I love this website
OK it could be the bulbs that is where I'd start the next would be fuses after that be sure to check your grounds and if its none of them check for broken or frayed wiring starting at the brake light sockets and working your way towards the front of the vehicle. it could also be the brake light sockets also.
