Door Glass Adjustment
Does any one know if there is a way to adjust the glass on a 70 cuda right door. The glass dosn't go up all the way short about 1/2" any help would be great. Thanks
I'm thinking that you need to adjust the window regulator itself the mount bolts should be in slotted holes so you can raise or lower the mechanisum to adjust the height or the rail the glass is mounted to has an adjustment for up and down however it would only be a slight adjustment. These are just guesses as i have never worked on a 70 cuda just thinking they should be simular to other mopars.
